SOURCE: wii fit balance board
You need to sync the balance board with the console. Instructions are in the manual. Sync button for board is in battery compartment and sync button for console is in panel under reset button.
Took a few tries for me, be carefule not to hold sync button on console down for longer than 10 seconds because it will deregister all wii remotes.
SOURCE: WII FIT BALANCE BOARD BLUE LIGHT WONT STAY ON
new batteries..... lol and then sync it again..
SOURCE: wii fit platform does not stay switched on after
have this message came out "an error has occurred. press the eject button and remove the disc, then turn the wii console off and refer tothe wii operations manual for help troubleshooting." i tried several times, but same message pop out. izzit something do to with NTSC?
SOURCE: my wii balance board wont stay on
First thing to do is install fresh batteries.If the Wii Balance Board is still experiencing power problems after trying new batteries and ensuring that they are inserted correctly, please call 1-800-255-3700 for assistance
http://www.nintendo.com/consumer/systems/wii/en_na/ts/balanceBoard.jsp
Put four AA batteries into the battery housing located on the underside of the Wii Balance Board.
Insert a Wii Balance Board compatible game into the Wii system.
Select the "Disc Channel" on the screen with the Wii remote, and choose "Start."
Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons.
Turn the Wii Balance Board upside down.
Remove the battery cover under the balance board to reveal another sync button.
Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady
Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
