Thanks for writing to Fixya.com.
The hot surface light is turned on by an auxiliary switch across the plate. Sometimes the switch gets stuck in the closed position. It is also possible that the plate is not turning off. Feel the plate and check if it is at all warm. If not, then the auxiliary switch is stuck closed. To resolve the issue replace the limiter which is the rod you can see across the plate. Sometimes you can only get the complete plate with limiter which is a bit pricey.
Thanks for contacting Fixya and please accept the solution if it has helped you.
Hi,this is a description of the problem you have with your unit.The element contains a sensor to detect when the element is hot, these sensors has failed and this implies that the element will have to be replaced.To be sincere,this replacement is a difficult one that requires experience,skill and technique,so please do the right thing.
Thanks and take care
Here is a tip that I wrote about why the hot surface indicator light will not go out...
Oven Hot Surface Indicator Light stays on
heatman101
