NO OS stated. XP?
That is correct. bad hard drives can click, that is the head servo
resetting, due to the brain inside finding gross errors.!
CLICKS:
Seen 100s do that. (the hdd with proper power (voltages 5v and 12vdc at spec) only clicks 2 times, on power-up and power down
called head retraction and parking.
so clicking can be 2 things, bad hdd, or lack of spec power to the HDD. Okay, it's is complex electronics here. we use a VOLTMETER to check power. 5v/12vdc
If you ran the software for S.M.A.R.T, it bleeds red errors like mad.
I bet.
Ok question 2: DATA.
how to get my data from a near or dead HDD.?
true dead, there will be no data.
OR (hope not)
it's too late now, backing up before HDD failures is best.
But you can do that, if lucky can get all or 1/2 the data, only FATE decides how bad it is, the drive or bad data.
If running w10 , the data you find will be needed to be to the new ownership. (use use added app,called takeownership to cure that)
there are also, great software you can buy to get all data. (may)
hDD moved to other PC as external HDD is best (esata enclosures top that list)
google hdd recovery software.
you will have to do a fresh install on to a new SSD (best choice)
there well be no chance of cloning any corrupted data, ever.
hopeless that.
http://pcdied.com/
