Roper RA58445KQO sn#CL4361705 type 111 I have lots of mold smell comming from the washer. I have cleaned around the tub collar and removed the bleach cup and cleaned around and under it. I removed the liquid softner unit and it was full of stuff. Does the top come off of it so I can clean it throughtly? If yes how do I get it off? How can I remove the ageator to clean it inside? How? Thanks for your help
SOURCE: taking roper washer apart.
Hi, It might come apart like this:
http://groups.msn.com/Appliantology/washers.msnw?action=ShowPhoto&PhotoID=283
SOURCE: Agitator Noise of Roper RTW4305VQ
yes this noise is normal.its the dog ears ratcheting in the agitator
SOURCE: No clips found! To remove top or front
Check out this diagram. Sure hope this helped and best wishes.
SOURCE: washer smells like mildew
This sounds like the pump is clogged up or the drain hose from the pump is retaining debris. The pump is easy to remove and check. There is a video at www.appliancehelponline.com/servicemanual.html check the video on how to take apart a direct drive washer. This will walk you thru the disassembly and the pump removal.
SOURCE: washer does not drain and spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
