Pyramid (Swr14) Swr&Power Field Strength Meter with Power Switch (10&100 Watts) Logo
A
Anonymous Posted on Jun 09, 2010
I bought A "new" pyramid phase iii meter model SWR-14 off of ebay. It came wrapped in bubble wrap without any instructions. Where can I download th manual? thanks
DROPNDEAL
Level 3:
Top Expert:
  • Pyramid Master 2,931 Answers
  • Posted on Feb 10, 2018
DROPNDEAL
Pyramid Master
Level 3:
Top Expert:
Answers
2931
Questions
0
Helped
932322
Points
21770
Not sure. Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
i bought A
1 Related Answer
Anonymous
  • 5158 Answers
  • Posted on Feb 01, 2009
SOURCE: need frequencies covered by pyramid SWR-14 meter
it appears to be only good for the cb frequencies.... i suspect it would be too unstable for 2 metre usuage
Robert
Please take a moment to rate this solution.. thanks
Emerson lc320em2 HAS A PICTURE FROM HDMI BUT NO SOUND IF I UNPLUG FROM CABLE BOX AND PLUG BACK IN SOUND COMES BACK ONCE I POWER OFF AND ON NO SOUND SOUND DOES WORK ON COAX CABLE
Chances are you have an issue with the main board. Those can be purchased on eBay for around $20.00. If you go the route of changing that board be sure to match the number of your board that is in the TV, don't search by model number as this model used several different boards and some are not interchangeable. One word of caution, use static precautions when handling the board, it should come in a static proof bag of wrapped in static bubble wrap ( generally pink in color) be at the set before unpacking the new board, just walking across carpet with it in your hand can damage a good board.Good luck!!
1helpful
Smoke unit doesn't smoke
First verify wire connections (use a Volt/Ohm meter if you have one). Second, verify RESISTANCE in the smoke unit coil wire. Chances are it will be "Open" and reading zero (0) resistance. Acquire new wiring through eBay or Amazon ... and re-wrap the wiring as per the number of wraps as per your Lionel Repair Manual.
How can i wrap a vase so that it won't shatter nor scratch?
The best idea to wrap a vase i to use bubble wrap. You should first of all gather some bubble wrap or some clothes and put them inside the vase so to roughly fill its emptiness. Then wrap a lot of bubble wrap around the vase, both on the sides and on top and bottom, rolling the wrap round and round and fixing it with tape. make sure its well padded and soft on all sides and corners. Then place the vase in a small carton box that fits it entirely and fill the remaining space with more bubble wrap so that the vase won't have enough room to move around. Then close the box well and write FRAGILE in red on the box.
How do you make a pyramid shape out of paper?
Wrap paper around your "Pyramid Car Amplifier". It will then be the shape of at least your "pyramid"! :)
I have a Radioshack trc-487 cb radio with weather band . I would like to turn up the modulation... Peak and tune... get better reception... anything... I would like to know the internal parts I have to...
Hello Randy, do you have a fiberglass or stainless whip? What is your SWR & power meter readings now? --- The stainless whip may be creating a feedback and picking up static from transformers. Do you have a power microphone? If so you need to use a modulation meter to set it for 100% modulation. It could also be causing the crackling, that or your engine alternator.
A 1:1 SWR implies a perfect match between all elements of the antenna system...this is what you want. If an antenna system is not working well, the power reflected by the antenna will travel back through the transmission line and arrive at the output of the transceiver. From a practical point of view, SWR numbers in the range from 1:1 to 1.5:1 are considered to be very good, meaning that the antenna is radiating most of the power sent to it...
I would not recommend tweaking the boards on the realistic radios. You can however tune your whip. Start by making a base coil with some copper wire, 14 gauge will work. Run one end under the whip mount end and then tightly wrap the wire around the base of the whip. Experiment with 20 - 30 wraps for best performance & SWR.
The Astatic 575M6, or the Sadelta MB-4(hard to find) are very good power microphones that will help with modulation and peak power transmissions. Let me know if you need more help with tuning, if the "crackling" is still there.
Here is a link for your radio, in case you don't have one.
http://support.radioshack.com/support_electronics/36554.htm
Pyramid phase iii meter model SWR-12 manual or print
Amp for 12" Alpine Type R DVC 4ohm
i actually have 2 12" type s's and i did the same thing just wanted a cheap amp... i went on ebay and bought a pyramid 1600 super blue series amp..... its 1600 watts and ive also hooked it up to type r's and it POUNDS!!! ill copy and paste the website where i got mine from on ebay... if you tune it right it'll make it so you cant breathe inside your car......http://cgi.ebay.com/NEW-1600-WATT-PYRAMID-PB559X-Car-Audio-Amp-Amplifier_W0QQitemZ350169009069QQcmdZViewItemQQptZCar_Amplifiers?hash=item5187b30bad
Micronta swr meter 21-525b
Fascinating. Recommend contacting a local car audio professional or Pyramid customer support directly here:
Roadpro swr meter is not responding when i connect it
Well...Recommend contacting a local car audio professional or Pyramid customer support directly here:
Top Pyramid Car Audio & Video Experts
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
xxxxxx xxx
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
