Most washers have an electric water valve in the back where the water hoses connect to the washer, and there are screens in it that can plug up with rust from your homes' pipes. The supply hoses may also have screens. If that is not the problem, it could be that the electric valve is bad, which is easy to change. First, as a repair man I always look for the simple fixes first, like making sure the water is turned on. Robin
Testimonial: "Thanks Robin, managed to get it after an hour or so fiddling around, now time to try and fix the dreaded ps3 :("
cheers Robin, managed to get it after an hour of fiddling around, now to move on to the dreaded ps3 :(
