for the whole car? its huge.
but you are in luck ,
someone, (not me) scan the paper book to PDF
the only book on trackers ever done by a very motivated guy
took him a week to do that, im sure.
as you may not know but Geo nor suzuki used PDF then. ever.
since 2007 http://www.acksfaq.com/trackerfsm.htm
old post
is this an electrical question?
the starter has 3 wires.
the ground wire goes to the starter mount bolt.
the hot wire Plus got the big , starter solenoid lug.
the small push on conn, only goes 1 places, the solenoid.
ALT
the lat has 2 connections.
the big lug ring lug, to the starter big stud
then just plug in the rear connnector
that be it.
from the schematic view and way is here.
correcting an old post. Do not listen to the guessing persons. this car is a V belt car. all are, by Geo 1.6L 89-98 (1.8L Suz, different car and matter) the 96 tracker is a 1.6L SOHC motor, they are sold with and with out A/C or P/S. "options" so are set up 4 different ways, ( i have the full 96 parts list)
1996 Geo Tracker Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White
Car Radio Accessory Switched 12v+ Wire: White/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Yellow
Car Stereo Dimmer Wire: Red/Green
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): White/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Light Green/Black
Right Rear Speaker Positive Wire (+): Gray
Right Rear Speaker Negative Wire (-): Gray/Black
Fig.: Before installing the timing belt, position the camshaft
sprocket (1) so that the timing mark on the sprocket (2) is aligned
with the notch (3) on the inside timing belt cover (4) ...
Fig.: ...and ensure that the crankshaft sprocket (1) timing mark (2) is aligned with the mark on the oil pump (3)
For more details, can register in autozone.com (free).
I hope help you with this (remember rated this help) Good luck.
Buy a Chiltons manual that covers theGeo Tracker,Suzuki Sumari - It will Have all the wiring diagrams in the back of the book - I know because I have one.
