Question about Bosch 24 in. SHX46A05 Stainless Steel Built-in Dishwasher
The dishes do not rinse properly--despite rinse
We have a 5 year old machine. Two years ago, it was completely rebuilt due to calcification build up in the hoses (we have very hard water and the machine had a heart attack). Since the repair, we have noticed the dishes just don't seem clean. They do not seem to rinse properly--despite rinse agent settings at max and switching from liquid to powdered detergent as recommended by a Bosch customer service rep.. The dishes just are not clean. How can we fix this?
  • 1,531 Answers
Run some calcium lime and scale remover throught the unit on an empty wash cycle just to get rid of any build up that may be there.
turn the rinse aid down to about half way.
also check the phosphours content of you washing agent.
there is a lot of factor involved with leaving film on the dishes, it could also be residual soap content that is sticking to your dishes.
reduce the amount of soap a little.does not matter if it is liquid or powder.
once every three months you need to run cleaner through the machine.
last thing but very important make sure the incoming water temp i no lowe rthan 120 degrees.
Posted on Jun 09, 2010
SOURCE:
1999 Honda Aero 1100c3. sat for two years with fuel in tank,carbs, etc. drained tank and carbs and cleaned, then reassembled. Bike will fire and instantly stall. Did have it running a month ago, but
remove carbs and rebuild completely, old fuel builds shellac in needle valves and other ports. clean float valves thoroughly, and check choke for proper operation
Oct 26, 2014 | 1999 Honda VT 1100 C3 Shadow Aero
My 5-year old Bosch dishwasher leaves a somewhat fine grit on dishes? especially obvious on the inside of glasses. I use only Cascade detergent, use a rinse aid, don't overfill the machine, and always...
I have the same problem with mine!! It's 6 years old, and I'm running loads of dishes through twice. Even that doesn't help! And I rinse the dishes too, so I have no idea where all these "crumbs" are coming from. Will check back for updates. Hope to get this problem solved!
Oct 01, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
I have maytag dishwasher leaves food residue
there is a filter on the inside bottom of the dishwasher check and clean it
May 16, 2010 | Maytag 24 in. MDBH970AWS Built-in...
White film and food particles on dishes
Did you check the incoming water quality, regarding hardness!
If your washing machine supports salt addition technique, fill the appropriate box and fill the salt that is meant for washing machines. Salt works as a softener.
Finally check your rinse aid also for it's fill in the dispenser meant for it
Apr 11, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Dishes have filmy finish
hello. this will help a great deal.
First of all empty out your dishwasher, toss in two cups of plain white or cider vinegar and run it on the highest and longest cycle.
Always run the hot water in the sink first and start the dishwasher only when the water is as hot as it will get.
This wash will clean out your dishwasher thoroughly.
Then always do your dishes after you have rinsed any residue off of them before placing them in the dishwasher and I always recommend the pot scrubber cycle if you have one.
Jul 07, 2009 | Dishwashers
The dishes don't get clean
Dishes not cleaned properly....
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Mar 31, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Dishes have soap residue despite using rinse aid. Machine is quite abrasive on coffee mugs etc. Unit is Fisher & Paykel DD605SS
use less soap.....excess soap in the rinse cycle will not allow the dishes to rinse properly causing white etching on the glasses and the dishes will have that gritty feeling
Aug 02, 2008 | Dishwashers
Bosch 24 in. SHX46A05 Stainless Steel Built-in Dishwasher Logo
331 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
