Maytag Neptune MAH5500B Front Load Washer Logo
Posted on Jun 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does not spin dry. Code LR - Maytag Neptune MAH5500B Front Load Washer
Anonymous
Level 3:
  • Master 594 Answers
  • Posted on Jun 08, 2010
Anonymous
Master
Level 3:
Answers
594
Questions
0
Helped
293820
Points
1864
LR is a error code for service on the unit. This code is referring to the motor not working properly and needs to be serviced.
please call 1 (800) 344-1274 U.S. to locate the nearest service provider or visit www.maytag.com
1 Related Answer
Anonymous
  • 10319 Answers
  • Posted on May 29, 2010
SOURCE: Will not spin cloths dry. Lr Problem
HERE IS a TROUBLE CODE CHART that you can download and SAVE for this to go by. I suggest to save it too for future reference
http://www.applianceaid.com/neptune8.html
Why is my Maytag washer showing lr code again?
If you live in North Hollywood, CA and need washer repair service call us at (626) 460-0903 or visit our website Washer Repair North Hollywood CA 747 248 4544 Samsung
What is Lr code mean.
The LR code means "Locked Rotor". This could be due to:
  1. The control board at the top of the unit has lost connection to the motor and its control board at the bottom. Check for loose connectors. Also try 're-seating' each connector by pulling it off and pushing it on two or three times.
  2. The motor and/or control board at the bottom are shot.
Error codeLr?
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason. By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing. The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down. You don't mention in your question if the LR code occurs every load or once a week.
More information on when the error is occurring would be helpful resolving this problem. Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down. This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes. At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
1helpful
What does error code Lr mean
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning. Usually when the LR code is displayed the motor has stopped turning for some reason. By definition the LR code means the control has tried to turn the motor but was unable to. The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing. The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down. could also possibly be the Water Inlet Valve w/Thermistor #22003834 needs to be replaced due to having Well Water with lots of sand, in the water it is not closing the valve properly allowing water to continue filling the tub, causing it to read the load being too heavy and also leaking out the front door
Lr code went into service mode but wont respond to commands model #fav6800aww
Tom,
The LR error code can be a tough one to troubleshoot but I'll see what if any help I can be.
The LR code stands for Locked Rotor.
If you Power Cycle the 120VAC to the machine will the error code clear?
What cycle was the machine in when you took the error code wash, spin?
If you remove the front panel and with the 120VAC power cord removed from the service outlet can you rotate the Clutch Pulley CCW (Spin direction) or CW (wash/agitate) direction.
Sounds like you have the FAV6800A/FAV9800A Service Manual.
Let’s see if the drive system is free and not locked up…………Rich
2helpful
1helpful
WANT SPIN AND THE DISPLAY SAYS lr
HI, the actual Motor control board that is located inside the unit is malfunctioning. this is the reason for the (lr) code you are receiving at this point. replacing the MCB, will fix this non spin issue.
1helpful
Fills with water but wont wash or spin
The code LR stands for locked rotor you will need a new motor and motor control kit pretty expensive and only covered under you warrenty for a year!
2helpful
MAYTAG NEPTUNE LR CODE
LR usually means that the the signal from the board is not getting to the motor either because of a bad connection at either the motor or the board or the motor itself is no good. Need to check the connections first.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
