Dremel 400 Series Xpr Rotary Tool Kit with Xpr Multisaw and Xpr Planer Attachment 400 - 6/90 Logo
Posted on Dec 15, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It appears that the locking mechanism that is engaged in order to charge out bits has stripped out. No matter how hard I press the button to engage the lock, it always slips when attempting to loosen the collar with the wrench...Is this a common wear and tear issue?? Is this easily fixed? Please advise...THANKS.
Nicole Paradon
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 29, 2022
Nicole Paradon
Contributor
Level 1:
Answers
Questions
0
Helped
1035
Points
This happened to me the first time I used and for less than an hour. I went to change the bit and the lock button seems to pop while trying to loosen the collar. I WD40 it and tried using a vice grip and still no luck. So I registered it as I just got it and now I guess I am sending it in to be repaired and or replaced. Was disappointed I couldn't continue to use it, but liked the 2050 stylo and what it achieved regardless. Hope they help me.
Alcolu John
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 151 Answers
  • Posted on Dec 18, 2017
Alcolu John
Expert
Level 2:
New Friend:
Cheetah:
Answers
151
Questions
Helped
109584
Points
333
This can happen if you accidentally depress the spindle locking button while the tool is running -- a common problem since Dremel did not include any type of interlock to prevent it, and the button is right where you'd hold the tool for best control. If that happens, you probably will need to replace the tool or send it to Dremel for repair.
5 Related Answers
Anonymous
  • 202 Answers
  • Posted on Jul 07, 2009
SOURCE: Craftsman rotary tool doesn't lock down on the bits.
the collet is either the wrong size for the shaft on the attachment or is missing alltogether
VtToolMan
Mark
  • 704 Answers
  • Posted on Jul 24, 2009
SOURCE: My Dremel lock nut won't budge. My collet is
You'll need to use either the built in shaft lock to hold the collet in a fixed position, or use a pair of slip joint pliers to hold the shaft of the bit, while you use the wrench to loosen the collet. Slow and steady should get it loose. Another option is use some penetrating oil sprayed lightly onto the back of the collet to help loosen it from the shaft etc.
radar001
Bob Korsu
  • 1051 Answers
  • Posted on Jan 14, 2010
SOURCE: 400 XPR - I am trying to remove a saw attachment.
The attachment is 'keyed to the motor assembly so it will only go on in one direction. If it was mistakingly forced on in a different manner it can get jammed. Try twisting it from left to right while pulling straight out.
Anonymous
  • Posted on Apr 26, 2010
SOURCE: I have a collet nut that will not loosen. at one
Sorry, but I seem to have ( essentially ) the same problem... no positive lock. holding the button down while rotating the shaft to find the "best hold" then applying extra pressure sometimes helps. I had no problem with an older model. 400 XPR also seems to overhheat badly.
My ultimate solution: purchasing the model 4000.
bzet1820
  • 700 Answers
  • Posted on Aug 02, 2010
SOURCE: can't unscrew collet
it is possible that you stripped lock mechanism on the collet, for the beginning, never, ever, use wrench to tighten the collet! just hand tied, if it slips, tight it bit more, but with hands only.
i never used wrench on the collet and never have any trouble with any of my dremels.
to close, just hold firmly in one hand pressing locket button, tighten up with other hand, to undo, reverse procedure.
if you find bit is too lose, then you have collet inserts, find that one which hold bit firmly and use it on this particular bit. standard collet is 1/8" (3.175mm), but in the set there are collets from 0.0394'' (1mm) to 0.177" (4.5mm). do not use wrench...
just inspect now if thread is not stripped, on spindle and on collar, if locket still hold, if these are damaged, you need to change damaged part. and follow the advice :-)
if you find this advice useful, pleasae do not hesitate leave your remark and vote4 for me, thanx!
1helpful
How do I turn off the lock function on the Rinnai ES17?
Lock function
This feature locks the buttons to
prevent unintended operation.
Press the Lock button to activate and
the lamp will glow.
Pressing and holding the Lock button for two seconds
will disengage the Lock.
If the Lock is engaged while the unit is
operating, all buttons will be disabled
except for the ON/OFF button.
off, then all buttons will be disabled. The Lock must
be disengaged in order to turn the unit on.
2helpful
2answers
H4 button not working in hdj81
Don't drive around with H4 engaged all the time. You will feel power loss on the highway and wear out the tires prematurely. Find another mechanic! Get it fixed right.
Sanicompact
Take off lid and check flushing mechanism if all engaging timely. Adjust if necessary. Good luck. BTW when pressing the button make sure you do it with a bit of pressure.
Jul 29, 2013 • Home
2helpful
2helpful
I have a 1994 toyota landcrusier and I know is allwheel drive and it supose to be allwheel drive at all the time but also has a little shift on the righ side that say high and low is an automatic truck I...
Driving a vehicle with diff lock on hard surfaces will damage the drivetrain. Try to avoid this. If your center diff is locked, be sure to press the button on the dashboard (Center diff) to the off(button out) position. (Yes, you didnt press the button, but your model automatically engages diff lock in 4lo) So dont engage 4lo on hard surfaces.
Try reversing a couple feet. This may free up the diff so that the lock can disengage. If this does not work, find a large patch of grass or gravel. Turn the steering to full lock(left or right, doesnt matter) and pull off. This should disengage the lock. It is good practice to engage the difflock at least once a month as this will keep the lockers lubricated enough so that they dont bind like yours have done.
3helpful
Can't unscrew collet
1helpful
I can't get the fn button to disable. when i use the keys on the right side of the keyboard, i get numbers unless i use the fn key. i thougth it was a toggle key
It appears the number lock has been engaged.
Press the Fn key plus one of the keys that has NumLk labeled on a key at the top RHS of the keyboard. This will toggle the number lock on and off, also there will be a LED light that shows when the number lock has been engage, just like when you engage the Caps Lock.
2answers
Hard to engage star power on wii wold tour
I think that there's a float like thing that acts like a level inside so if the thing can't move easily oil it or losen the screw a little bit. But what do I know i'm only 13 years old.
4helpful
Stove manuals for Crosley Electric Stoves
how do I operate the self cleaning function on my stove model
cs37500-1
Top Dremel Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
