Rio S10 MP3 Player Logo
Posted on Jun 08, 2010
How to add music via storage card - Rio S10 MP3 Player
1helpful
How to load music to my samsung galaxy?
I have a Motorola Droid, but the same approach is likely to work, since they're both Android 2.0+.
Here's what I do:
1) I rip/store my music using Windows Media Player on my PC.
2) When I'm ready to transfer, I make sure Windows Media Player is open and then I connect my Droid to my PC using the provided USB cable, which happens to be the same cable that connects the phone to the charger. Plugging the phone in like this makes the phone storage visible much like a flash drive.
3a) At this point, Windows Media Player will recognize the storage and you will be able to sync your music library to it.
3b) Alternatively, the phone storage will be accessible via a drive letter. You can put your music files under the Music folder at the top of the "drive." (I prefer 3a, because it organizes the music better.)
I'm not familiar with Macs, so I can only speculate that the same idea should apply. The heart of it is that music goes under the Music directory at the top of the add-on SD memory card. The phone's music player is supposed to find and use all music files anywhere underneath that directory.
2answers
HOW TO USE MP3, HOW TO DOWNLOAD SONGS
Hello there,
You have to connect your phone to the computer via a USB cable. It should be detected as a mass storage device. From there you can start dragging music files from your computer to your phone.
On how to use the MP3, there is a shortcut for the music player.
2helpful
Trying to add storage space unable to add music with new mlcro sdhc 8g memory card. mp3 player says music wont fit.
The Sansa e-series works with microSD cards. While microSDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use microSD cards, 2GB and smaller.
Music`
In markets you wil get the memory card readers for this type of memory cards. Please purchase it.
Insert the card in the slot where it suits and connect to the PC.
It will get detected in your PC.
Now you can use it like Pen drive. Its just a mass storage device.
Please follow the steps to copy music file to your memory card
1Select the music file you want to transfer to it.
2.Right click the file,You will find a option as Send to ,when you click it,it will show your storage device.
3.Click on it it wil be transfered to your memory card.
I have attached photo for your easy understanding.
How do you add music to the music player wihout downloading
Well, this may not be what you asked for, but what you can do is: if you have a SD Card, you can copy your music from your computer to the SD Card via a USB that has an SD Card Slot, or if your computer has this, a SD Card slot built-in to your computer.
How to put music on micro card and play on phone
put ur card in a jacket and put it in a card reader and connect itto pc. add ur songs. out it back into phone and open music player.. update ur music library and play the songs.
or connect VIA DATA CABLE and add the songs
1helpful
Cant play the music
Add music to I9
Connect your i9 to your PC via the USB cable.
On the phone select "Mass Storage Device".
On the PC you will see 2 new drives appear.
One will be the SD card. The other is the Phones internal memory.
Now just simply copy your MP3 files to the Memory card folder "My Music".
Do not use the phones internal memory as it just is not big enough.
The Audio player will only play music from a folder called "My Music" or "MP3"
depending on which firmware version you have on your i9. If one doesn't work try naming it the other!
Also make sure you are selecting the right storage area in the Audio player options, either the phone
or the memory card, because there can be identical music folders on both, and if you don't choose the
correct storage location, your music files still won't show in the Audio player!
Make sure the audio file is in a format the i9 can play. Known music file types are mp3, wav, amr, m4a, & mp4.
DO NOT place music in sub folders within either of the My Music or MP3 main folders, the Audio player
will not find them unless the music files are directly within the proper My Music or MP3 folders!
Every time you add new music to your i9 you will need to refresh the List in order for the audio
player to see all the newly added songs. To do this open the player. Tap "List" at the bottom of
the screen. Tap "Options". Tap "Refresh list". You can also go into the audio player settings &
turn ON the "List auto gen." option. If the option is ON, then after you add new music, the new
music should be added to the entire list of music already showing. If you have problems with the
music list showing up empty, or new music you have just added not showing up in the current list
of songs, then try turning OFF the List auto gen option and refresh the list manually again by using
the Refresh list option as described earlier. Manually refreshing the music list must be done every
time you add new music files to the phone if the List auto gen option is OFF.
You get to the List auto gen option by two ways with the Audio player open and onscreen
for most i9 firmware (some firmware might not have it, or may be in another area);
1.) Tap the little wrench icon to the far right on the black option panel,
then scroll down to the List auto gen. option!
2.) Tap the List option at the bottom of the screen, tap the Options button
screen, tap the Settings button, scroll down to List auto gen.
3helpful
3answers
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Transferring music
If you want to move music you must use some file manager or explorer!!! It's no need to do that, to move! You can play from your card!!! It's not a problem!!! Just go add files in WMP and select file which you want to add in card or from internal phone memory!!! Because your phone memory is 64mb and it's not smart to overflow it!! It will decrease your mobile speed and stability!!!
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
ADMIN Andrew
ADMIN Andrew
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
