Posted on Jun 08, 2010
Paperjam J3203 and J7540.Konica Minolta Bizhub pro C6500
Paperjam J3203 and J7540.One sheet of paper just out of de machine in the RUunit and one just before de duplex and declurerrol
Anonymous
Level 1:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Jun 08, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
17
Questions
6
Helped
3633
Points
46
Pull out the paper carefully and next time use atleast "20 lb. paper" 24 lb is better.
Konica Minolta bizhub PRO C6500. Hello, can anyone help me? Do I have a problem with code C2221?
Question edited for a lot more clarity.
Question translated to English, we only speak English here.
Question moved from Televisions category.
Konica Minolta Bizhub PRO C5500 Solution Manual (Page ...
ManualsLib https://www.manualslib.com > ... > Solution manual
Reconnect the terminal. 2.Failed ...
Accurio c2060 error c2221
Copytechnet https://www.copytechnet.com > ... > Konica Minolta
Jun 26, 2023 - C2221 can be caused by toner dusted sensors PS50 & PS51. I've seen C2221, when the drum bore fits too tightly onto the drum shaft. The imaging ...
Error Code C-2221 on C7000
Apr 3, 2019
C6500 Error codes C-2211 - C-2214
Aug 7, 2008
bizhub PRESS C1060 multiple codes/symptoms
Jun 21, 2022
C6500 C-2220 error
Jan 22, 2014
More results from www.copytechnet.com
Error code c0101 - Konica Minolta Bizhub Pro C6500 Color Copier Color Printer
Printer control board (PRCB) or Paper feed motor (M41) is bad hope its the motor board will be expensive!!!!!!! check behind the draws paper stuck!!!!! also pull out each draw find if thats the problem
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Error code C-2704 mean on C6500 Bizhub Pro
Abnormality in the black charging unit.
Possible causes:
Black charging unit
HV Unit
Print Control Board
My best guess is that you have a faulty charge unit. Try swapping the units around with another colour and see if the fault code shifts.
2helpful
2answers
6helpful
2answers
Konica minolta Bizhub C6500 error code 2424
Hi, I have a C6500 Bizhub pro, but, recently displays an C2404 error. I need to print an urgent job and y can't!
Please helpme!
k24674
ADMIN Andrew
ADMIN Andrew
