HP Compaq Presario CQ50-110US Laptop Logo
Posted on Jun 08, 2010
When I move the The laptop screen turns green and fuzzy
Anonymous
Level 1:
New Friend:
  • Contributor 54 Answers
  • Posted on Jun 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
54
Questions
0
Helped
9481
Points
95
Restart the notebook and press F10 to enter into BIOS which should be blue in colour. The move the laptop and check if the screen turns green and fuzzy.
If the screen turns green and fuzzy in the BIOS, then the isuse might be hardware malfunctioning of the screen and your notebook needs to be repaired.
1helpful
My screen gets fuzzy contact need cleaning?
Try to connect laptop to extern monitor, if picture on an extern monitor OK, then You must exchange display ribon cabel.
My screen is all fuzzy
It maybe used for several years, so this is common. or suggest you to contact Acer for tech help.
Android 4.0 Tablet PC
Laptop screen occassionally turns fuzzy and stops when moving laptop screen.
This is a hardware problem that will require repair from a technician, please contact your manufacturer for assistance.
Screen turn red and fuzzy, hard to read
then the problem is from the screen so what you will have to do is to change the the screen before it become worsen ok
6helpful
2answers
When I open my laptop the screen becomes green and fuzzy. This is until I move the screen slowly backwards and eventually I hit a spot where it comes back to normal but if I move the screen forward or...
The ribbon cable to the lcd layer (green pixel contact common) is going bad or the connection of the cable to the lcd unit is dirty. It is probably the connection, as the ribbon cable, if installed correctly, will flex many more times than the hinges would be able to (that is, the ribbon cable should outlast the laptop). Sometimes they might not be installed correctly in that there is a hangup or kink of some kind and the bending (each time the laptop is opened and closed) makes it bend beyond the elastic limit of the metal, and it eventually cracks. The problem you have may be cause by the cracked metal in the ribbon cable, and careful placement of the screen makes the cracked trace reconnect by flexing. It could be caused by a bad contact of the cable to the board or (most likely) the screen unit.
If you are inclined, take apart and carefully inspect the ribbon cable for any parts that have a kink in it or is otherwise flexed too much in one small little area. Flex the cable to see if it changes the display. Otherwise, wiggle the ends (careful) to see if it will try to work.
If you find a cracked cable, have it replaced. If the contacts prove to be dirty, unplug or otherwise remove cable end that is dirty and reseat cable after carefully burnishing contacts and using contact grease (smathering only).
Toshiba laptop screen dicstorted
Loose electrical connection or its loosing its grip to hold your screen. If you can do it on warranty then try. Or have it check by a technician.
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
