I have a second hand sony ericsson w302. when i put in my sim it ask for my sim unlock code after that it start to ask some for thing in a other language. like (Dig cod telefone)
SOURCE: Sony Ericsson - phone lock code
Hi Cheryl!!!
I think i may have a solution for u. It sounds like a Phonelock code...all Cellphones have one. Its in the software for the phones. Its a little like a SIM code. U could try with entering the code 0000. That could work!!
Good Luck :-)
SOURCE: unlock a sony ericsson w302 from virgin mobile
hi
You have to call your phone provider to ask for the code. They can provide you instructions to use the code as well. Or you may try using this:
**05*PUK code*New Pin*Confirm New Pin#
Hope this helps.
SOURCE: pc suite for sony ericsson W302
You don't need software to do this.Fitrst you need to add your your phone as a bluetooth device.If everything worked allright then there should now be a Standard Modem over bluetooth in your Phone andmodems control panel.Then you need two services to be running, goto taskmanager and set both Remote acces connection and Telephony to automatic (right click>properties) and also start them both.
Now go to Control Panel Network and sharing and click Setup a network connection then choose connecting to the internet then choose dial up connection then choose Standard modem over bluetooth , type *99# as phone number leave the rest blank and there you go , you have a internet connection over your mobile.
Good Luck
SOURCE: The sony ericsson PC suite v6.0 does not detect my
Check your cable. try to connect phone on a different computer
