Cameras Logo
A
Anonymous Posted on Jun 06, 2010
How do i set up my camera for underwater use?
Anonymous
Level 2:
Novelist:
  • Expert 162 Answers
  • Posted on Jun 08, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
162
Questions
0
Helped
50926
Points
407
Hi. I would suggest that you look for the best underwater gear for the model of your camera. Hope This Helps
Picturess are too green
there are advanced color correction modes,
Blue or dark pictures/videos
Keep your shooting distance inside of 2ft to 3ft, depending on
visibility and ambient light.
If you are using only one light, considering adding another light
(dual lights) or/and external flash accessory. The ideal
set-up is a combination of a light plus flash.
Consider purchasing the SeaLife Wide Angle Lens (SL975). The
fisheye lens allows you to get closer to the subject and fit more
into to picture frame.
For SeaLife camera with external light accessory (No external flash):
1) Set the camera's scene mode to Sea mode or Snorkel mode
2) Change camera's PHOTO and VIDEO White Balance
settings to DAYLIGHT.
For SeaLife camera with external light and flash accessories:
1) Set the scene mode to Ext. Flash mode
2) Change the VIDEO White Balance setting to DAYLIGHT.
For other underwater camera brands:
1) Set the Scene mode to "Auto" or "Underwater" scene
mode, as recommended by the camera manufacturer.
2) You may also need to change the White Balance setting to
DAYLIGHT depending on the camera's underwater color
correction or if pictures/video turns out red.
Is canon ixus 50 is waterproof?or can use underwater?
No, the IXUS 50 is not waterproof. You cannot use it underwater without an underwater housing.
No, the IXUS 50 is not waterproof, you cannot use it underwater without an underwater housing.
My Olympus Stylus Tough -6000 lost its underwater capability. it gets wet no matter how much i make sure the battery and USB gaskets/seal clean. can it still bi fixed? how?
I wish there was a way I could shout this to everyone so they would all know it at once....ALL SO-CALLED "WATERPROOF" POINT AND SHOOT CAMERAS WILL EVENTUALLY LEAK. THIS WILL USUALLY HAPPEN AFTER YOU HAVE TAKEN THOSE "ONCE IN A LIFETIME" PICTURES. The only real underwater cameras are in a special underwater housing.
2answers
I have purchased an Ikelite AF 35 strobe to use with my Sony DSC-TX1 camera and underwater housing. Even with the strobe set to the lowest setting, the photos I take with the camera set to 'housing on' are...
akdenny, have an af35 myself and know from experience the issue is very likely to be the way you have the block out for the cameras flash. if you block it by having the tape inside the housing it confuses the af35 to fire at a higher setting. from what i can gather it senses the strength of the camera flash and adjusts. I get the best results with the blockout on the camera supplied diffuser, stops the flash camera going forward and gives plenty of light to get the af35 to fire right. to blockout i just use some black tape , fabric tape seems to stick well.
you will still need to set the auto level setting.
hope it works out, i find it a great flash. and the guys at ikelite very very helpful.
Is there anyway to make my underwater pictures better if I do not presently have a red filter. Can you suggest a program that I might be able to use?
Hello Guest,
Please set the manual white balance on your IC800 while you are underwater, especially at depths below 20 ft and reset it every 20 feet deeper. PLease refer to your IC800 manual. If you don't have the manual anymore, you can download it at http://www.intova.net/support/intova-manuals/ . If you have further questions, please call us directly at 808-837-0074 or email [email protected] .
Best Regards,
Intova
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Recording From Underwater Camera
I have a gs11EB. I don't it's possible to record into this camea from an external source?????
2helpful
3answers
Vupoint underwater camera -fuzzy pictures
My girlfirend just got me this camera and I've noticed that it takes fine pictures when the lighting is good. Under low light (i.e. underwater or in the dark) it's not so hot. I don't think there is a fix for that.
Feb 13, 2008 • Cameras
2answers
Can my pentax optio WP can go underwater without a water housing unit? How deep under can it go?
The pentax optio WP can go underwater without a water housing unit. It can only go underwater about 5 ft.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
