When i insert my memory card with reader and try to open it it is show { disk in drive is not formated do you want to format it now?} how can i repair my micro sd card 2 GB
I've been encountering this issue. The problem may come from the card reader or the card holder. If possible, use a different card holder and of problem persists, try a different card reader or test on another computer.
Well, formatting it immediately is not recommended. There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article memory card not formatted - how to fix & recover to learn more the right fix step by step. Best regards.
HI there,
It seems that your memory card is infected with the virus which restricts you from formatting,
To Format the memory card:
Take out the card from the cellphone, Insert your memory card in the card Reader, (External more preferably or internal memory card if you are using laptop),
When window recognize that memory card is inserted , Just hit cancel and do not open your Memory card.
Right click on my computer and select Manage
Then Select Disk Management
it will show you the list of installed Hard Drive, DVD , and memory cards,
right click and select your memory card (On the left size you can see the size of the memory card)
and select Format, a pop up screen will come and you can select format options.
Select Perform a Quick Format. and then click OK, it will format your memory card, and all the data will be erased from the memory card,
Caution: Always select the right partition in Disk Management for formatting to avoid any possible data loss,
If you require more assistance, feel free to reply to this post
Regards-BA
Insert your memory card into your computer's reader if you
have one. If not, you can purchase a multi-format USB Memory Card reader
from Amazon.com or Buy.com
Open up 'My Computer'. You should see it under the list of
available drives.
Check its contents first to make sure that you have the right
drive.
In 'My Computer', right-click on the drive and choose
'Format'.
5
Leave all the options as they are and click on 'Start'. This
is a non-reversible process so make sure this is what you truly wanted
to do in the first place.
6
Once the process is completed, take the memory card out and
insert it into your Digital Camera or any other device. Try to browse to
it to make sure it works fine now.
try formatting ur card with the following steps:
right click om my comp then click on manage then disk menagement and right click on ur card then format it will forcely format ur card. gud luck....
available drives.
drive.
'Format'.
5
6
I had the same issue with my 4GB Sony Memory Card when I put it in my memory card slot on my computer. I have a Toshiba laptop, so what I did that fixed the problem is I went to Toshibas Support Webpage in the downloads section and under the CATEGORY: Driver Card Reader and re-downloaded:
Ricoh Card Reader for Windows 7 (32/64)(v3.54.02; 09-04-2009; 4.94M) and once I did that it read my memory card and didn't give me any more issues and it opened all my pictures. Of course if you don't have a Toshiba then you would go to your manufacturers web site and see if they have the same thing, because that is what fixed my issue and it didn't take long at all.
#1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com #2 Open up 'My Computer'. You should see it under the list of available drives. #3 Check its contents first to make sure that you have the right drive. #4 In 'My Computer', right-click on the drive and choose 'Format'. #5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place. #6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
5
6
