I am using a Dell Vostro 1510. Suddenly the display which comes after we perform any Fn key related action has stopped. Eg. The volume battery hibernate actions do not come up with a display on the screen
Hi, Wireless can be enabled/ disabled on Vostro 1510 by holding Fn Key and pressing F10. When wifi is on, it is indicated by blue LED indicator with wifi signal icon above the keyboard as shown below:
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
Go to advance diagnostics by pressing Fn key + power key or by pressing F12 while startup select diagnostics it will perform a diagnostic testa dn then will give u an option for advance diagnostics select keyboard and then follow the steps. It may be that particular key not working but to fix it u may have to replace the keyboard,because there is no way by just single key caN be replaced.
Ok, it's handy to keep but ok. Make sure you press and hold these keys till it changes. Number Lock+Fn+Delete and it should turn it off.
Hope this helped. Good Luck!
Quickly and repeatedly press each key on the keyboard.
Due to the impact, one of them may have become "stuck" in the "down" position, and thus is interrupting the start-up of your computer.
When you hold the Function button on the lower left down (Blue Fn) and hit the F keys the action in blue will occur. Fn + F8 will switch video output for example.
After a long use, some keys get stuck i.e. it seems normal but the button under the key remain in contact. Your problem seems like this. Try to open the key board and check the button. It may solve your problem.
