THE PUMP IS LOCATED IN THE FRONT OF THE MACHINE.
CHECK IT FOR A HOLE IN THE FRONT CENTER OF THE PUMP AND CHECK IT WHERE THE MOTOR SHAFT CONNECTS TO IT. IF YOU FIND ANY MOISTURE THERE, REPLACE THE PUMP.
THE WAY TO CHECK IS PULL THE WASHER OUT AND TIP IT BACKWARD FAR ENOUGH TO BALANCE IT AGAINST THE WALL. THE PUMP IS RIGHT THERE IN FRONT. WHITE WITH TWO HOSES ATTACHED TO IT.
IF YOU CAN'T GET TO IT THAT WAY, REMOVE TWO SCREWS FROM THE FRONT CORNERS OF THE CONSOLE. IF THEY AREN'T THERE, LOOK IN THE BACK OF THE CONSOLE IN EACH CORNER. THEY ARE PHILLIPS HEAD SCREWS. REMOVE THEM AND PULL THE CONSOLE TOWARD YOU AND PIVIT IT UP AND BACK OUT OF YOUR WAY. THEN REMOVE A CLIP FROM EACH CORNER THAT HOLDS THE CABINET TO THE BASE BY INSERTING A SCREWDRIVER IN THE FIRST HOLE THE CLIP GOES INTO.
CATCH THE FRONT OF THE CLIP AND PRY BACKWARDS ON IT. THIS WIL LIFT IT UP AND OUT OF THE HOLE.
THEN PULL THE TOP OF THE CABINET TOWARDS YOU AND
LIFT IT OFF THE BASE. WATCH CAREFULLY SO YOU CAN PUT IT BACK ON IN REVERSE ORDER.
NOW, YOU SHOULD HAVE ACCESS TO EVERYTHING.
How do you get to the front of the machine?
How do you get the top of the washer off?
