I have added towels to the bedding to help prevent the balling issue but this doesn't help. The bedspread and sheets get into very tight balls and sound like heavy balls being banged around in the dryer. I have to take them out every 10 minutes and rearrange and still it takes forever to dry.
Balls don't work. The only solution is to unball the sheets every few minutes. It is the dryers fault: they way it's designed. It's not the milkman's fault.
Try putting dry pillows in with them. They will take up some of the extra space in the dryer and may prevent the sheets from being able to get into a ball.
That's common sheets are always a problem,i don't have this problem but i hear tennis balls in the dryer stop this from happening,two tennis balls should do it.if not try three.hope this helps,also i read if you tie two opposite corners together loosely it helps and adding towels also helps with the two corners tied
SOURCE: Is there anyway I can
You can put one or two tennis balls in with them. There are also dryer "balls" that stores sell but tennis balls work too!
