I just got a Samsung Blue-Ray player and i want to use the digital optical output from the player to the receiver. With the optical cable hooked up I gat sound when I first turn the player on but I don't get any with a disk in. I have tried setting the audio output to all three settings (PCM, Bitstream re-encode, and Bitstream audiophile) with no change.
When you say you have sound from the BD prior to disc load... where (TV and/or receiver)? Initial wake-up audio is usually 2-channel.
Describe the optical audio connection input to the receiver and any other audio paths that are attached.
Do you have other multichannel sources you could use to test this, like a cable TV box?
There's an obscure setting in the receiver called PCM Fix (on Page 21). Give that a look.
It is a Samsung DB-C5500
It is a Samsung BD-C5500
