SOURCE: My tag heuer aquaracer has a problem: the second
Your TAG is fitted with EOL (end of life) feature. This is the cause of
that 4-5 seconds interval movement of seconds hand and thus indicating
the time for battery replacement. The timekeeping is not affected by
this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
SOURCE: Tag watch second hand skips
Yes it's the battery. Please make sure to take it to someone QUALIFIED This watch requires that all the gaskets be replaced and pressure tested at the time you have the battery replaced
Donald McPherson
www.finewatchmaking.com
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
SOURCE: Tag Heuer Link, stopwatch seconds hand stops 2 seconds before 12
Pull crown out to position 2 [in between unscrewed (1) and pulled all the way out (3)]. Tap Button B (bottom) to reset by step back to zero.
Incidentally, Button A works Hours register in same manner for position 2. You can similarly reset second and 1/10th with Buttons A and B, respectively, while in position 3. Cheers!
SOURCE: Tag Heuer CA 1211-RO Min. Hand resets to 59 Min.
Unscrew the crown and pull out halfway. Use the stopwatch buttons to advance the hand to where you want it. Then push the crown back in and screw it down. You may need to pull the crown out all the way--I cannot recall which setting controls the minute hand and which the hour hand on the stopwatch function. This has to be done every time the battery is changed.
