Whirlpool 24 in. DU1148XTP Built-in Dishwasher Logo
Posted on Jun 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dishwasher quits running and clean lite keeps flashing.
Anonymous
Level 3:
  • Master 8,619 Answers
  • Posted on Jun 06, 2010
Anonymous
Master
Level 3:
Answers
8619
Questions
Helped
2150320
Points
26471
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
WON'T END WASH CYCLE/KEEPS ON RUNNUNG..IS THERE A CODE FOR THIS
If you cannot cancel the cycle then turn power off and back on.
Then try to program a short cycle from panel and see if it works.
I am assuming when you say that it keeps running you mean the water keeps churning and does not drain out.
If short cycle works ok then the dishwasher is not heating water to the correct temperature. Need to check thermostat or heater.
20helpful
2answers
Control clean light keeps blinking and dishwasher will not function
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run your dishwasher as normal.
If this same light appears again then you have a bad element or thermostat.
3helpful
AS PER DIRECTIONS FROM TECH, I PURCHASED AND INSTALLED A NEW CONTROL UNIT. THIS WAS BECAUSE MY WHIRLPOOL DISHWASHER GOLD GU2300XTLB3 QUIT WORKING IN ALL CYCLES EXCEPT SHORT CYCLE. PUT EVERYTHING BACK...
This is a common problem with Whirlpool washers.If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has until all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 01, 2010 • Dishwashers
1helpful
Clean lite is flashing
This is an indication that there was a failure to heat the water properly. I have put together some instructions on how to reset the control so you can use the dishwasher and some things to check to avoid this problem again. Follow the link below and let me know if it was helpful.
Clean light flashing
THe Dishwasher just keeps Washing And Rinesing
Turned Fridgidaire washer on last night before going to bed; this morning, it's running (at least making sounds) but did not wash; 4000 Series Frigidaire; display says Washing Drying Er Clean S; and two lights are flashing - Ultimate Scrub and Rinse only.
I tried turning off the breaker and restarting the machine but that doesn't work.
I have kenmore dishwasher and the clean light is flashing green and nothing else will start.
To reset hit buttons in this order- hi temp, air dry, hi-temp, air dry. All lites will come on. You can then hit cancel. If problem recurs then unit is not washing for some reason. Keep me posted. Please leave feedback.
"Lock on" light keeps flashing - cannot run dishwasher
same issue..
Other boards suggested heating element issue - but nothing very clear or compelte.
1helpful
2answers
Keeps flashing clean Kenmore dishwasher 665.17019401 need a new owners manual
i was trying to install my kenmore elite 665 dishwasher but i cant find the plug do they come with one? or were do i hook it up?
Sep 22, 2007 • Dishwashers
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
