Dear Scotty Jacko ,
My suggestion is please download all thedrivers and applications again from this site:
http://www.hauppauge.com/pages/support/support_pvr250-350.html
i'm 100% sure that the application WINTV 2000 is faulty ,in your installation CD.
try it and enjoy.
Cheerup and be happy always.
Error: Win/TV Initialization error, a required component (Hcwtvwnd.dll) is missing:
Fix: that error indicates a mix match in the driver files. The latest wintv driver and application for nt must be installed. Found here
http://www.happage.com/Pages/support/support_pci_878_nt2000-nt.html
Alos if that does not work, please try installing this Software Beta Lite CD
http://www.shspvr.com/smf/index.php?topic=6680.0
A WinTV channel does not necessarily indicate a Tuner channel. You can,
with WinTV, set up a series of channels that include Tuner inputs,
Composite Video inputs, and S-Video inputs. For example, a group of
channels may include channels 2 through 13 as tuner inputs, then
channel 100 as a composite video input, and channel 200 as an S-video
input.
This error message indicates that the WinTV middleware/channel manager is missing.
If any more question just Ask me please.
And if it fixed your problem Accept my solution and rate it as fixya.
Thanks
Iqbal
This error will only come up if the VFW drivers have been installed on the system. For example, if you had a different model WinTV installed that requires VFW drivers and installed the PVR 250/350 software over it, you may get this error. You may also get this error if you have downloaded and installed the PVR PCI updated drivers mistakenly.
The WinTV PVR 250/350 DOES NOT USE VFW drivers. To correct this error, run the PVR48xxx.exe file from the PVR folder on the WinTV PVR 250/350 installation CD.
just run the software and make setup
and plz Accep my solution i.e. iqbal_del
Thanks
Iqbal
Which software are you using please give the version
Hi
Click on this link and download the latest updated driver and then try using it. it should work fine and do let me know
Thks
http://www.nodevice.com/driver/WinTV2000...
Please dont forget to rate fixya
Error Code 10: This device cannot start.
Try moving the WinTV card to a different PCI slot in the system. If
there are any resource issues with the WinTV card and any other device
in the system, this would reassign the resources for the WinTV.
Open
the Control Panel - System - Advanced. In the Performance section click
on the Settings button, then the Advanced tab. In the Memory Usage
section located here, choose Programs instead of System Cache.
Make sure that the latest drivers for your VGA card are installed as well.
To setup channels download the manual from this link
http://www.hauppauge.com/pages/support/s...
Dont forget to give fixya
version 3.4A
i have done that and now the error is htv = 10
that is fantastic help but how do i now setup the channels
