Question about Frigidaire 15,100 BTU Heavy Duty Window Air Conditioner
My ac is not blowing cold air. the fan will only blow warm air. It seems like the compressor is not working.
    Scholar:
  • 45 Answers
The unit may be low on refrigerant. There is probably a low pressure switch in the unit to protect the compressor so it wont turn on and get damaged beyond repair. You can take it to your local appliance repair shop and have it looked at. I would get a quote on repair first. Most of the time it is cheaper to buy a new unit than it is to pay just the labor to have it repaired.
Posted on Jun 07, 2010
SOURCE:
AC blows warm air. 07 GMC Envoy 6 cyl. 4wd
You probably replace the wrong switch. I believe the high pressure switch is mounted in the back of the compressor. Pull the plug and jump it. If it works, replace the switch. I don't recommend you leave the jumper in the plug. If it the A/C pressure is to high, you could blow lines and such. Costing you a lot of money.
Jun 24, 2015 | AC Cars & Trucks
AC not working
Has anyone checked the freon charge ?
Jun 28, 2013 | 1996 Isuzu Trooper
Air cinditioning wont stay on, it switches to heat and wont shut off
What do you mean when you say it wont shut off? is it blowing hot air or do you just feel a lite flow of hot air even if you have the settings to cold?
If this is the problem that you always feel hot air at low flow and the ac goes to hot air then i would say one of two things, first if you have the selector to cold and you feel hot air then there may be a problem with the blend door, this door move to allow hot or cold air, the door may be broken or just a bad motor that controls it. keep in mind if the ac system shuts down for any reason the air then will be warm, it will be about the same temp as outside and maybe a little hotter.
this problem almost sounds like the ac compressor shuts off and then you are getting the outside air which is hot, there are many reasons for the compressor to shut off, it could be the compressor clutch heating up and disengaging , this would be due to a bad compressor clutch.
another reason is the fans are not working, the best thing to do is when the system starts to blow warm check and see if the compressor is running, start engine and look at the front of compressor, with ac off the front of it will not move, and then with ac on the front will spin, check it out and let me know, if it blows warm air and ac is not working then it may be compressor problem but if you are getting warm air and the compressor is spinning then it may be a door problem.
This is hard to check with out testing the system, so i listed a few things to check and let me know the out come. also the ac blows cold for how long before it gets hot air blowing out of the vents, good day.
May 25, 2012 | 2000 Dodge Grand Caravan
I have a 2004 2.7 6 chrysler sebring lxi. ac blows really cold and periodically just starts blowing warm air. is there a relay or temp. sensor that might be going out and through a malfunction shuts down...
Cooling fans working? If you notice the air getting warm mostly while stopped, probaby cooling fans not turning on. if the fans are working properly, may be low on freon and need a recharge.
Jun 26, 2010 | 2004 Chrysler Sebring
AC blows warm air at idle
your a/c fan may not be working or slow, if not then your compressor is starting to fail. you could save it by changing the freon and compressor oil, if not the you have to change it.
Apr 26, 2009 | 2007 Dodge Ram Truck
Running fine but blowing warm air
"it seems to work fine but will not get cold"
Not sure how it can work fine and is not cold. When you say work fine, is the light on and the freezer fan blowing but is the compressor running?
Unplug the Ref and wait about 30 min or so, plug it back in and listen for the compressor to start running. You should be behind the Ref to hear this. If you don't hear it start running then you may hear a clicking noise. This clicking is a problen with the compressor start relay. If the compressor runs but still is not cold then it could be low on coolant.
Dec 16, 2008 | Refrigerators
Aircondition not working....just blowing warm air.....fan is working
Either you are out of coolent or the compressor is not working.
First check the fuses, then lift the hood and have a friend turn the air on. The compressor should cycle, if not take it to a mechanic. If it does cycle you are low on freon, take it to a mechanic for a system charge. Make sure they check for leaks first.
Aug 04, 2008 | 2001 Mitsubishi Montero
Frigidaire 15,100 BTU Heavy Duty Window Air Conditioner Logo
596 people viewed this question
Top Frigidaire Heating & Cooling Experts
Donni Steen
Bill Long
Pete Norton
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
