Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
Posted on Apr 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A colour bar blue on the bottom and green on top of42" LCD
I am useing a HD box from Shaw Cablevision (made by Motorola) hooked up to a 42" Zenith LCD. Have good reception on both digital signal and HD Channels.
However I have a yellowish-green fuzzy bar 2-3" across the top of screen and a blue fuzzy bar 2-3" across the bottom of the screen. Have tried calling local service centre to no avail. Contacted Zenith USA as set was bought in washington state and given to me as a gift. They were of no help! Please send any hints or tips you can. Thanks
Bud Maindonald ([email protected])
  • chekeyc Apr 10, 2008
    Where do I find the service menu. Also where are the fuses located?
    Thanks for the relpy Bud.
    Will keep you posted as to progress.
    I asked and they didn't think it would be the lamp!
    Thanks Bud
Ginko
Level 3:
  • Zenith Master 19,396 Answers
  • Posted on Apr 10, 2008
Ginko
Zenith Master
Level 3:
Answers
19396
Questions
25
Helped
8073303
Points
55462
You need to replice the convergence ICs.
  • 1 more comment
  • Ginko
    Ginko Apr 10, 2008
    It is a rear projection, not lcd, therefore it should be a convergence problem. Afull convergence test should be performed from service menu. If you still have the problem after setting up convergence, you will need to check the fuses at the base of convergence IC and change convergence ICs.
  • Ginko
    Ginko Apr 10, 2008
    My first answer was wrong, your model is a rear projection LCD TV, not a projection tv (the tube ones). Therefore it is not an IC problem.
    As already posted, it is likely that you need to change or adjust the lamp. Here are replacement in Europe, post your location to get more options:
    http://www.e-av.co.uk/info.php%3Fid%3D50...">ZENITH E44W46LCD Lamp
    £261.00 - E-AV Pro Audio
    http://www.filron.com/uk/index.php%3Fact...">LG E44W46LCD Lamp (Original)
    £219.29 - Filron UK
    http://www.filron.com/uk/index.php%3Fact...">ZENITH E44W46LCD Lamp (Original)
    £241.23 - Filron UK
    Regards
  • Ginko
    Ginko Apr 10, 2008
    It is correct , you should not replace the lamp unless you are a technician or an advanced DIY. Lamp costs over US$400 and must be tested before being replaced. There may be many additional reasons why the LCD tv is displaying horizontal bars. May be a problem with some component on the main board, or a misplaced LCD display cable.
    Turn off all appliances aroun your tv, if you have an option for using a traditional uhf areal use the tv with aerial only, and check if you still have the bar, alternatively try moving tv to other room. Problem of this kind may be generated by disturbance from an heavy appliance nearby (fridge, big amp, transmitter), or by a defective cable.
    If you cannot get rid of the problem it may be neccessary locating a tv repair in your area.
    If you want to DIY you will need to start from getting the service manual with diagrams and part list, it costs $25. Here is also a forum on problems with your model, if you ask them they may get service manual for free.
    Regards
Ekse
Level 3:
  • Zenith Master 13,435 Answers
Ekse
Zenith Master
Level 3:
Answers
13435
Questions
82
Helped
3983116
Points
38023
It sounds like a lamp problem, did the support guys say anything about lamp possibly failing?
  • Ekse Apr 10, 2008
    Agreed with ginko. In some models the lamp can be easyly changed, I dont know about this one.
Where do I find my link code
Link code for which service provider? See below:
CableVision UR2-CBL-CV04 code: 096
Charter DIGITAL code: 0463
Comcast M1057 code: 0463, 10463
Cox COX code: 0463
Direct TV RC23 code: 10463
Dish Network VIP508 code: 720
Dish Network VIP622 code: 720
Motorola DRC800 code: 0463
One for All URC-6690 code: 0464
Phillips PDVR8 code: 115
Phillips PH5DSS code: 115
Phillips PHDVD5 code: 115
Phillips PMDVR8 code: 115
RCA RCU807 code: 135
Rogers DCT3250 code: 0463
Shaw DCT3416 code: 0463
Sony RM-VL600 code: 8043
TiVo HD code: 0091
TiVo SERIES 3 code: 0091
1helpful
Remote code for 26" LCD Dynex tv
Remote code for who? Dish network? Comcast?
Cox COX code: 0463
TiVo HD code: 0091
2answers
I turn on the Tv the sound comes on & the picture is blank Cablevision was here & said it's a problem in the set
He is probably not an expert (just kidding, of course he's not..) First, try connecting the Cablevision Box to another TV (if you don't have another HD TV, use the yellow/white/red Composite connection.) If there is still no picture, the box is no good. If there is, then try a different output from the Box or other inputs on the TV. Are you using HDMI (HD connection) out of your Box? Is the TV 720p or 1080p? Set the Box up (from the menu) according to the specs of your TV. Hope I helped.
17helpful
4answers
LG HD 37 INCH TV GREEN LINE APPEARING ALONG THE BOTTOM
On a LX2R to remove the green bar at the bottom or the blue bars on ths side using the sky HD box go to menu and the pip menu at the bottom of the list, access input and make sure the HDMI input is on DTV and NOT PC.
Colours turns blue and green from HD channels
The most likely cause of your problem is the cable box HDMI output. If you have some extra cables, try connecting the TV to the cable box using the component connections. I'll bet your problem will go away. Don't let the cable company lie to you; I work on Sony TV's everyday and see plenty of cable box HDMI issues. Some of my customers have exchanged their boxes 4 or 5 times and still have HDMI issues. Your best bet is to use the component outputs or switch to Dish or Direct TV, as they DON"T have HDMI problems. If this solution works, be sure to rate it. Thanks!
Red Vertical Burn Line on LCD Screen
Try changing the picture setting on the television rather than from the picture box.
2answers
Picture selection
If you have a motorola HD box turn off the cable box...press menu on cable box front...select 4:3 override stretch and TV type 16:9
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
