The problem is that the mouth piece of your phone is bad
that is why the cannot hear your voice. I advice you get the mouth
piece of your phone replace because it is bad and that is why your
callers cannot hear you.
All you need to do is to change the
mouth piece of your phone and you will see that your callers will hear
after you have replace the mouth piece of your phone.
Meanwhile,
you can get hands free pending the time you will replace the mouth piece
of your phone.
The
problem is that the mouth piece on your phone is
malfunctioning that is why people call or people that calls you barely
hear you. All you need to do is to replace the mouth piece of your
phone and you will see that after the replacement of the mouth piece,
anybody that call you or people you call will hear you clearly.
Just
change the mouth piece as advice and you will see that the problem is
solve. meanwhile, you can be using hands free pending the time you will
replace the mouth piece.
The
Just
The problem with your phone is the mouth piece, the mouth piece of your phone is bad that is why you cannot be heard while you call.
I advice you replace the mouth piece by changing the mouth piece on your phone. replace the mouth piece and you will see that you will be heard after you replace it.
Meanwhile, you can be using your hands free while calling before you replace the mouth piece.
The fault should be from the mouth piece of your phone.
Use a phone screw driver to loose the phone, remove the mouth piece and clean the phone board, especially the mouth piece area of the board. Put the mouth piece back and make sure it contacts the phone board very well. Couple back the phone and test it.
If it still gives the same fault, the I think you need to change the mouth piece completely.
If you cannot get another mouth piece, then I would advice you get a hearphone to receive and make calls for the main time, till you get another mouth piece.
Hiya........... have a good look at the door seal for any visible tears... do it with wet hands... and the electric off!! If you cant see anything... Have a look at the pump couplings.. for any visible signs if leaking!
Not sure what the question is.
