Dear Soulfire,
Set your gadget settings to factory defaults........
how?
Normally this type off errors occurs due to faulty settings or corrupted software.
If after resetting problem persist then, contact your network operator and find that whether there is problem from that side........ If then also problem persist then update or re install your software......... After updating also problem persist then Sorry there is a hardware problem. Get it serviced......
If you cannot make calls and fixed dialing is turned on, verify that the phone number for your contact appears in your fixed dialing
list or turn off fixed dialing it also apply on text messages.
To turn off fixed dialing, click the trackwheel. Click Disable FDN Mode.
I cannot recieve or make any phone calls or texts. it hangs and times out. when i make a phone call it says no service availble. Its having trouble communicating with the tower. but my wife uses the same service and her phone is working fine.
Ok so the phone is really not connected to your wireless service and the best way to have that check is to contact your phone provider so they can also check your account. Try also by the way powering off the unit for about 1 minute to refresh it.
called. phone should be working they say. tried taking battery out. didnt work.
If that's the case try do a reset on your phone. Do the restore to factory settings on the phone
This problem happens on pretty much any computer-related device.
Something happens and you can send
anything. It’s annoying, but there are actually two ways to fix it. You
can perform a soft reset, which is done by pressing the ALT + CAP +
DELETE keys on your handheld at the same time. If this doesn’t work,
perform a hard reset. This is done by finding the RESET button at the
back of the handheld. Sometimes, this button might be near the bottom,
under the battery cover. Press the RESET button using a pin or paper
clip. With either method, you shouldn’t lose any data.
Perhaps, is you did not see the reset button,you can also do the hard reset this way, in the process of powering your phone, pull out the battery straight before it finish loading, this helps fix abnormality on the blackberry phone.
Take care.
Signal bar on my blackberry phone.. It has an arrow flashing to the NorhtEast like it is trying to contact a tower, yet i have a signal. But when somone calls me it goes to my voicemail. When i try to make a call it says "no service availble". It suddenly started doing this.. i did not drop phone or anything like that. My service is through PagePlus, which is a prepay that uses Verizon towers. My service is currently active.
I have a tower signal coming in at 4 bars on my blackberry 7130E. It has an arrow flashing like it is trying to contact the tower or something. The arrow flashes constantly. I can not make phone calls or receive them, or texts. I have exhausted all advice given me so far. Nothing has worked. Its almost like the phone itself cannot contact the Verizon tower.
