PF Oven Error Code ShopYourWay
https://www.shopyourway.com/questions/1161483
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/53991-error-code-pf-oven-not-working.html
A part replacement is suggsted in the links above, but a technician might discover something else, rather than a particular part, as the internet search showed several possibilities.
SOURCE: GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
[email protected]
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
SOURCE: whirlpool electric range RF361 bxdn 0. error codes? PF?
hi Jon
look on the back of the unit, there should be an envelope that has a paper in it, that paper should tell you what the code means.
SOURCE: whirlpool accubake oven error code
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
It may just be a door switch
SOURCE: F3 and F2 Error Codes
If hitting clear/cancel won't clear it try unplugging and then plug it back in. My guess is the oven control is bad. Here are the fault codes for this model.
Failure
Code
Condition
Check/Repair
F0 or F1
Failed transistor in control
If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
F2
Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked
If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
F3
Open oven temperature sensor circuit
Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact
F4
Shorted oven temperature sensor circuit
Same as above; check for melted connector or both leads shorted to ground
F8
Component failure within Electronic Range Control (ERC) effecting temp processing circuits
Replace Electronic Range Control (ERC)
F9
Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch
Check wiring and test operation of switch
SOURCE: Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
