Garden Logo
Anonymous Posted on Jun 05, 2010
John Deere garden tractor 445, I am looking for cheaper prices for John Deere parts. The dealers are too expensive
Anonymous
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Jun 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
18
Questions
Helped
12726
Points
45
Join the JD tractor forum on Yahoo.
The hydraulic lever on my John Deere 445 garden tractor will not hold the float position on blade or snow blower work. Is there a setting or does something need to be replaced?
See
https://www.tractorbynet.com/forums/john-deere-lawn-garden/321064-445-float-detent.html
and links from there.
Cleaning the SCV Will likely get it working again.
How do i check my hydaulic fluid for my 445 tractor
JD Mower Maintenance - YouTube
? 16:56
https://www.youtube.com/watch?v=RYeP_QLhsoU
Mar 31, 2013 - Uploaded by GreenMachine757
Doing routine maintenance on my John Deere 757 zero turnmower. ... DIY Mower Seat Repair - Garden Tractor Seat - Zero Turn - eXmark ...
John Deere Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages6/
Service Transmission - John Deere Ag - New Equipmentmanuals.deere.com/cceomview/OMM144042.../OMM144042_D010.ht...DO NOT mix oils. These tractors are equipped with a hydraulic wet disc PTO clutch.... DO NOT use type "F" automatic transmission fluid. John Deere Low ...JD 445 Rider Mower Issues - Need Help Please - GardenWebforums2.gardenweb.com > Garden Forums > TractorsNov 12, 2009 - But I've read a lot of threads hoping to read about my issues, and was ...What tools I don't have my friends do, and both are real mechanics, big Deere fans ....it steer hard due to lack of fluid in the hydraulic steering cylinder. ... You may need to add fluid, run the tractor around a bit, and then check it again.
1helpful
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
445 john deere-temp gauge flutuates between hot and normal
Try replacing thermostat.might have trash in it causing it to stick on occassion.
1helpful
John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
1helpful
2answers
How can I tell the year of my John Deere 445 lawn tractor. Product # M00445C096237 ?
1993: 010001
1994: 020001
1995: 030001
1996: 040001
1997: 050001
1998: 060001
1999: 070001
2000: 080001
2001: 090001
http://www.tractordata.com/lawn-tractors/000/0/4/45-john-deere-445.html
Mar 10, 2010 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
