Wii fit weighin too light!
I would suggest that you ensure that the board is calibrated properly and that you don't step on it until directed to do so. I'm sure you're already doing this, because it won't let you go on without doing so.
The other solution I would offer is to change the batteries in the unit, and ensure that you are setting the Balance Board on a smooth, sturdy, and flat surface. If you are on shag carpet, it will not function properly. If you have average carpet, try using the little adapters that attach to the feet.
Remember that for the purposes of this program, the exact weight isn't what is most important, but relative weight. Any time you are tracking weight loss, be sure to mark your progress using the same scale. If you chart the Wii vs traditional scales, you should notice that the decrease is the same, regardless of what your starting point may happen to be.
