Broderbund American Greetings Creatacard Platinum 8 for PC Logo
Posted on Jan 25, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I get this error message in Create-a-card program in Forget me not. "FMNOT caused a general protection fault in module FMNOT.EXE @ 0006:C4E9". It asks to cancel or ignore. Any ideas on how to solve this would be greatly appreciated. I've done chkdsk, scanning for viruses, remove and re-install.
Joseph Wright
Level 3:
  • Broderbund Master 1,729 Answers
  • Posted on Jan 25, 2018
Joseph Wright
Broderbund Master
Level 3:
Answers
1729
Questions
Helped
455330
Points
5127
Just a thought: I would remove Quicktime and try the program again. If not prompted to install Quicktime, uninstall the program, install again with the Quicktime version they provide. That will possibly associate the program or its extensions with Quicktime. You can probably update Quicktime after that. Save any work to another folder before uninstall so you don't have to so it over, replace it after the reinstall.
1 Related Answer
Anonymous
  • Posted on Feb 19, 2010
SOURCE: create card problem run time error Fmnot32.exe
rename fmnot32.dat to fmnot32.old, rename fmnot32.bak to fmnot32.dat, then restart. It fixed mine today! Good luck
1helpful
When I try and load a card stitch I keep getting the following error message: PCDWIN22 Caused a General Protection Fault in Module PCD_WIN.EXE at 0005:38F6
Perhaps this will help:
http://162.220.55.147/F/support/t3266679-r_n
Could be incompatibility of the machine software and the card software. Might want to contact the manufacturer of your machine for more information.
I am trying to install Titanic: Adventure out of Time for Windows 98. My computer currently has Windows Vista. I keep getting the following errors while trying to install the gam: this file does not...
Welcome to Fixya. The problem that you have occurs because the program or application that you are trying to install is not compatible with windows vista. The game was released before the release of windows vista or even xp that's why it is not working. You can check the maker of the game and see if they release the patch for the windows vista version if not then there's no way you can play it on your system.
Thanks
2answers
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
3helpful
2answers
Problem Event Name: APPCRASH Application
Please try disable the Data Execution Prevention(DEP) or add the Yahoo messenger.exe in Data execution protection (DEP) exclusion list. This error is comming because you have enabled DEP. I think it will help you to fix the issue.
Thanks for joining Fixya community...Good Luck
Hi I'm Kandy When I try and load a card stitch I keep getting the following error message: PCDWIN22 Caused a General Protection Fault in Module PCD_WIN.EXE at 0005:38F6. The software then shuts down. I...
I replaced my USB/Serial RS232 port adapter with a genuine RS232 serial port on the PC. THis solved the problem. Further reasearch on the net indicated that USB to RS232 - serial port converters do often have problems. I previously had not had a problem running on Windows XP and this is what alerted me to the possibility of the USB/RS232 port adapter as a possible reason for the "new" problem.
1helpful
Problem Event Name: APPCRASH Application Name: iexplore.exe
I think it is a usual problems, u can try to delete some bad application or spam or anything from : internet explorer - select tools - then internet option - in tab general, choose delete and then checklist all components there - and then OK
if it is doesn't works, you just have to enabled/uninstall your internet explore through program files or registry
hope works,
BIRD.EXE won't run
Try this for the sound problem http://www.learnatglobal.com/XPUpdate.exe , download the file and run it. I had to run a DK program that I have in compatibility mode for win95, 256 colours and 640x480 screen res. hope this helps
9helpful
2answers
Error message says sound decompression software not installed
This is the solution my friends...loaddown patch from:http://www.gspsupport.co.uk/media/patches/XPUpdate.exe
I should charge for this...well...today I'm mr. nice guy...enjoy it
Windows dvd maker
What OS are you using? Ultimate, Premium, Basic?
Windows DVD Maker has stopped working Issue : While trying to create DVD in Windows DVD Maker in Vista, or while creating a DVD from Windows Movie Maker, which uses Windows DVD Maker, the burn process stops with error message.
Error message : " Windows DVD Maker has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. "
Cause : Windows DVD maker stops working because of incompatibility with one or more codec files which are outdated or incompatible with the particular project or the DVD Maker software itself.
Resolution :
These Codec files should be located and renamed to resolve the issue.
1. Open Start menu and type Event Viewer in the Start menu search bar. Open Event Viewer from the menu.
2. In the Event Viewer window Click on Windows Logs in the left panel
3. Click on Application Logs under Windows Logs
4. Locate error messages listed in the Central panel of the Event Viewer window and double click the error to check if this is log is related to DVD Maker.
Sample Error Log :
Problem signature
Application Name: DVDMaker.exe
Application Version: 6.0.6000.16386
Application Timestamp: 4549b5b0
Fault Module Name: nevideohd.ax
Fault Module Version: 4.6.15.0
Fault Module Timestamp: 459bb828
Exception Code: c0000005
Exception Offset: 00008b89
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1062
5. Locate Fault Module name, it should be a file with extension .ax.
6. Once the file name is identified, try to locate the file in C:/Windows/System32 folder. ( Please click on Show Contents if the files are not listed Automatically ).
7. If the files are not listed in System32 folder, search for the file, with search containing system files and folders.
8. Locate the file and rename it.
9. Check if the issue persists. If the issue persists and the error message again appears, locate the new .ax file that is causing the issue from the Event Viewer, error log.
These steps will resolve the issue instantly without a restart.
2helpful
2answers
Software problem
I had the same issue when I tried to print. I had to set my default printer to an older printer. Everything else worked fine. If you get this error when printing hopefully you can reset your default printer. I don't think the software has updated printer drivers for some of the newer printers.
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
