The date and time function is not working on my camera. It is set correctly but it won't imprint on the picture. I've tried but can't get it to stamp.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
SOURCE: Canon SD 1000 time and date stamp on downloaded photo
You can download the manual from the link below: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=323&modelid=14901 From page 37 of the manual it looks like you can only select the time stamp in "postcard" mode. Also the date & time need to be set in the camera first. Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Powershot A720 Date Function
Do you want date/time stamp?
If so, you will have to be in postcard resolution.
To achieve this you will put your camera in shooting mode, hit function/set button, arrow down to bottom left corner where you will see L, M, S and postcard modes. Select the one that looks like a postcard.
Hit function/set to get out of there. Now hit menu and go to setup menu (tools) and arrow down to date stamp and make sure it's on date and time.
images shot in this resolution will look good as 4x6 prints, but should not be printed any larger or they will look pixelated, not good quality for larger prints.
Either that or you can add date and time in the Zoombrowser program that came with your camera should you need larger prints with date/time stamp.
I hope this helps!
SOURCE: I AM TRYING TO SET THE DATE & TIME TO APPEAR ON MY PHOTOS.
you can only do date and time stamp under function button go to bottom where you can change size of pictures -go to right to W or wide-this is only setting you can do date time stamp on-when you change pic size and go back to menu you will see it highlighted and you can now turn it on-equals about a 2-3 megapixel size picture only-also just leave settings alone and have printer add it-date and time our always in pic data and most printers can add it
SOURCE: date stamp will not show on my camera
I found the solution o-line. All I had to do was switch the camera to the 'postcard' mode and instant presto, I was able to access the date stamp mode. I want to express my thanks to the (I don't remember who) person who posted the solution.
SOURCE: cannot turn date stamp on in menu settings.
Date stamp is only possible when you set the resolution (picture size) at "Postcard 1600x1200" option, if the date stamp is set to "Date & Time" or "Date" option
