You will have to change the power on your breaker ... take the white off and put it to the neutral bus. This will change the power beig delivered to the pump. In the motor, remove the white wire and put it on L1 ... black should already be on L1.
A side note ... 220 runs more efficiently and your motor will run cooler and at less expense. I suggest you not change it unless there is good reason.
