Gaggia Titanium Espresso Machine Logo
Posted on Jun 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello I have a problem with y machine. I have got a message "Ventilate", and i have pushed the button 26, but nothing happens. What to do?
espressonist
Level 3:
  • Gaggia Master 1,711 Answers
  • Posted on Jun 06, 2010
espressonist
Gaggia Master
Level 3:
Answers
1711
Questions
Helped
652019
Points
5029
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jun 30, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
2775
Points
7
Just had this problem. Machine continually needed ventilation with poor/no hot water & steam flow.
Fault was worn/broken steam valve cam (p/n 140640300) which is molded plastic & apparently prone to wear/breaking a critical "pin" on it so that it does not properly operate the steam needle valve.
Saeco Royal Machine says "ventilate", but when we
Hi
For the Royal Pro there is a button that has a drop sign(water drop) on it. You have to push the drop button to flow water from the steam wand. This should clear the ventilate but if it doesn't check my other tips for "Ventilate"
My machine wasn't used for a while and the "VENTILATE" message appears. I followed the instructions in the manual as I have done before but no hot water runs when pressing the button 26 and the...
I have just had the same thing this morning with my machine (not used & ventilate message). I followed the instructions & found the same as you, then I realised I had not turned the knob to dispense the water!! Try this, it does take a while for it to go through the ventilate process, I had to refill the watertank. Good luck
2helpful
Machine wont make coffeee, m,essage says ventilate...
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
3helpful
Cannot solve "Ventilate" problem - weater circuit is broken
Turn the knob on after you press the hot water button, run the cycle until the message is gone takes a few seconds or about 2 ounces of hot water.
12helpful
2answers
How to ventilate a saeco cafe royalecoffee machine
Hi
There is a water button you need to push. It has a water drop on it. This will clear the ventilate message.
Gaggia titanium espresso ventilate is on the screen.I press button 26,nothing happens
Hi
When you push the water button, then open the steam knob. This will allow water to flow. If you don't get water to flow check the water tank and make sure that it is down on the machine completely. The other thing that will not cause water to flow is a restriction in the flow meter.
Ventilate sign is showing and nothing works
Open the steam valve when the hot water words appear above the ventilate
Ventilate
bad chip get if repair my friend good luck.to verify keep it unplug for some days then replug back.but since the posing of this article,you can plug it now and lets see what happens.if it does what it do again call a tech.your machine has a bad chip if it is the embbeded chip buy a new machine.good luck my friend
Top Gaggia Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
