I replaced the chemical injector on my genrac model g24h, but it still does not feed chemical.
cleaned out the housing, with air and wd40, wondering if there is something else i should try... please offer any advice
How long is your high pressure hose and what diameter as it maybe to long and won,t **** chemical due to back pressure. To test this remove the high pressure hose and run the machine and check too see if any chemical is coming up the pipe. If it does then its a problem with your hose or the adjuster is not going to low enough pressure.
