Toshiba CT-90251 Remote Control Logo
Posted on Jun 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nothing is working but the volume and mute buttons,i cant turn it on or off or change the channel with the remote,the menu button doesnt work either,nothing nut the volume and mute
James DuPont Jr
Level 2:
  • Expert 91 Answers
  • Posted on Jun 04, 2010
James DuPont Jr
Expert
Level 2:
Answers
91
Questions
0
Helped
22842
Points
272
Some of these remotes are also made to run other components,so be sure to press the "tv" button and try the vol and channel again!
Cant use menu
You may need a different remote. Is this a universal remote? Some of them have these common problems. Mine, for instance, doesn't use the OK button at all; instead, the Menu button counts as the OK button.
Try navigating the menu with the TV's volume / channel buttons (the ones on the TV itself, not on the remote). This usually works. Try that until you get a different remote.
Volume button on tv doesnt work no remote
two choices, get the keyboard on the set repaired or get an original sharp remote which among remotes is not too expensive.
The remote doesnt work with the tv at all. and when i try to change the channel manually with the button it says no input availiable. but the volume button works just the channel button that doesnt. I...
UNPLUG THE SET FOR A WHILE AND PLUG IT BACK IN TO SEE IF IT WILL REBOOT-sounds like a microprocessor problem and could have been caused by a power outage etc.
1helpful
Ive got a urc-3920 One for all remote . All functions works perfect , but the AV button mutes the TV. Cant change to AV with remote.I've pressed all buttons on the remote to see if it has not been switched...
i have a goodmans tv GTV69RFDT and i have brought a one for all remote urc-3920-urc 3940. All the codes dont work, i have tried the seach method and still nothing is working properly, i get the number buttons and volume but no up channel and down or menu button. Need help
Dan
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
7helpful
2answers
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
1helpful
2answers
Toshiba 42h82
1. ENTERING TO SERVICE MODE
MUTE
S
(Service mode display)
3) While pressing the MUTE button,
press MENU button on TV set.
2) Press MUTE button
again to keep pressing.
1) Press MUTE button twice
on Remote Control.
2. DISPLAYING THE ADJUSTMENT MENU
1) Press MENU button on TV.
Adjustment mode
Press
Press
Service mode
Item
S Data
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
2answers
ESA ET413E LOST INSTRUCTION MANUAL, NO SELECT KEY!
when picture is displayed on your tv after pressing menu,press the channel up/down button on the remote or tv. there can also be a button that shifts right to left. this may hilight the the settings you want to change. if the up/down button scrolled you thru the settings, then the right/left buttons should change the settings.
hope it works
wg
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
