Electronic Arts Fifa 10 2010  And Sealed for Xbox 360 Logo
Posted on Jun 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
FIFA 10 - screen freezes after manager mode game
The game finsishes I press a button to skip the replay and the next screen freezes. In the top right hand corner it looks as if the words "achievement accomplished" are there. I can't move on from this screen, I can't even turn the xbox off. Any advice before I trade this game in?
Giselle
Level 3:
Genius:
  • Electronic Arts Master 1,015 Answers
  • Posted on Nov 27, 2019
Giselle
Level 3:
Genius:
Answers
1015
Questions
6
Helped
286594
Points
2407
Just restart it, it will work, if doesn't work, try to delete it, and install it again, I solve this problem on my PS4, hope this can work in your Xbox, you can buy cheap FUT 20 Coins on FIFACOIN.com.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Jul 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
167400
Points
Well i would install it on the xbox if you have a hardrive then try playing it through game library go to it and click play on it it should start working properly
2helpful
I reset my action replay DSi and now I can't use it and the DSi code manager says that I don't have enough space when it is cleared of game and codes. It also will not let me add new games and codes.
connect acton replay to pc
load the code manager
right click on the program in the top lerft of screen
choose about action replay from the pop up menu
click on the reset action replay button
you will lose all codes on the system but it should work
hope this helps ya
1helpful
3answers
XBOX 360 FIFA 10 Freezing
Several ideas: Change second controller to #3; eliminate saved configurations; save game on HDD. One of these should work for you
3helpful
Action replay doesn't let me add codes in custom code list!!!!!
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems:
* Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes.
* Code Manager PC software is reporting the console`s battery is low when it’s actually fully charged.
* Multicolored bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes.
* You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased.
1. With your console powered off insert the Action Replay DS
2. Hold down buttons A+B
3. Turn your console on
4. With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
5. Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
6. If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
9helpful
I wiped all my games! HELP ME!!!!!!!!!!!!!!
i had the same prob
* Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
from codejunkies
1helpful
My ds wont accept the ards. My other ards wont put any new games in the bottom screen it goes blue and red?My computer (windows vista)doesnt accept my ards
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems: * Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes. * Code Manager PC software is reporting the console`s battery is low when it?s actually fully charged. * Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error. If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased. With your console powered off insert the Action Replay DS Hold down buttons A+B Turn your console on With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen If Action Replay DS doesn?t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again whats an ard? from code junkies
I hooked it up to update overnight the next morning it wasnt finished so i took out the plug later i tried putting some cheats on my game and it said uknown version and some code on the bottom
try to reset it.
My action replay zeroed out.
the ds cartridge need to be reset.
do it by using this method.
you can tell if it needs resetting by;
2helpful
2answers
Action Replay DS has deleted avery single cheat code it came with
source codejunkies
5helpful
2answers
My Ds Action Replay Went BLANK!
i have had a similar prob it wiped all the games andm then i could not put more on because it went multi coloured when i tried so i hap to reset the entire thing to do so(source codejunkies):
copyed from code junkies
Top Electronic Arts Video Game Consoles & Games Experts
ADMIN Eric
ADMIN Eric
Don A
Don A
Are you an Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
