Day before was working fine went to play last night and the console will not even come on even after swithing plug in and everything.
First things first. We'll start from the beginning. Unplug the AC Adapter from the wall and from the Wii. Let it sit for 15 minutes. Then plug it back in. 9 times out of 10 your power supply needs to be reset. The only way to reset it is to unplug it from the wall and the wii and let it sit for 15 min. Try this first and report back if it worked. Even if you think you have done this already do it again.
Unplug the AC Adapter for 3 to 5 minutes plug it back in and turn on the console.
The day I was playing the Wii I had it on and unplug it without turning it off. then I unplug averting and let is sit for an hour and plug averting back into the Wii
Unplug for 15 Min. worked great.
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
109
Been unplugged at both ends for days now, still won't work. Is there anything else it could be?
Solution previously stated of unplugging for 15 minutes works great, just did it. thanks
Man, this thread made my day! Thanks, mine is working now as well.
It worked thanks
Thank you very much i tried that and it worked.brilliant.
Wii not coming on
SOURCE: day before was working fine went to play last
aqrtyctr-35
wii was working fine the next day we went to put it on and theres no power to it done the usual changed fuse tried differrant sockets but nothing.it is stil under gurantee but car/nt find it.
Brand new Wii. Played yesterday was fine, but to it freezes up at the first screen. I tried several times to switch it on and off but it doesn't start. anyone could help please?
Wii console will not turn on. We have unplugged
wii will not turn on. It has no power. I just now unplugged the AC adapter to try that. I'm not sure what to do if that doesn't work. Does anyone have any ideas?
the same problem, light is not coming to console....
Was working fine we didnt use it for a couple of weeks. Plugged it in and it wont even go on. Got it for Xmas hasn't been used alot. Any suggestions?
Our nintendo wii will not come on. Â We played it last about 48 hours ago and it was working fine. We have not used it very much at all. Â We got it in early May.
Played the wii for one week and the power will not come on.
I was having the same problem. When I went to turn on the wii console it wouldnt turn on.
Power will not come on. Was not used more than ten hours. Nothing wrong last time we played it.
I have found that if I borrow my nephews cord and plug the wii into it mine will come on. He can then plug mine into his and it will work fine. He had the same thing happen to his so he came and plugged his into my power cord and his worked fine. So every time it happens we switch power cords. Unplugging it for 15 minutes has not worked getting a spare power cord cord will reset it.
Wii console just conked off while i was playing. Now it does not even startup.
The power is on and the lights are all on, but then nothing happens.Â
The Wii console worked last night, but today won't turn on. No power at all. I've unplugged and plugged back in everything that I could find. Now what?
Our console has no power at all...worked fine before. Trying solution suggested, we'll see if it works in 15 mins or so.
My wii droped after my sister kicked it on mistake only once and its never coming on ever
wii console will not turn on
We played the WII just about everyday since we got it in January'09 and then we didn't play it for about 2wks and went to turn it on the other day (around the 10 of March) and it will not turn on. We have tried unplugging from wall for 15 min up to an hour. Plus have tried blowing air into vents on console... Nothing.... Still will not come on.. We have even tried changing plug in sockets... Still nothing... Any ideas?
I used my Wii around the 16th of February, but haven't used it since. It's been about 3 weeks since I last used it, and now it won't turn on at all. I've tried using different outlets, but it's still not working. Any solutions?
played 3 nights ago but tonight no lights and will not power up. changed plug in and everything.
