Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
In order to find the wireless security password of your Netgear wireless router , please follow these setps
1. Open up the internet explorer in the comp in which you are online and clear the address bar and type in the number 192.168.1.1 and hit enter.
2. You will be logged into the Netgear router setup page .
3. Under the wireless settings you will find the security password for your wireless router.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Install the router. To install a Netgear wireless router, use an Ethernet cable to connect the router to the cable/DSL modem and use another Ethernet cable to connect the router to your computer. Make sure all of these devices are powered off as you connect them. Once connected, turn on the cable/DSL modem, the router, then the computer, in that order. Allow at least two minutes to pass after turning on each device to give the devices time to recognize one another.
Log in to the router. Open a web browser and type in the router's address to load the router's settings page. The router's address can be found in the user guide or setup CD that came with your router, or you can download a user guide from Netgear's technical support page (see Resources). Most Netgear routers use one of the following addresses: http://192.168.1.1; http://www.routerlogin.net; or http://www.routerlogin.com. Press "Enter" or click "Go" in your web browser after you have entered the address.
Enter the router's username and password. A prompt will appear on the screen when you enter your router's address, requiring you to enter a username and password before you can access the router's settings page. The default username for Netgear routers is "username" and the password is "password." Because the textboxes are case-sensitive, you must enter both of these using all lowercase letters. Press "Enter" to log in to the router and begin changing its security settings.
Open the security settings menu. The router's home page has multiple links for changing settings. Find and click the "Security Settings" link to change the router's security settings.
Change the SSID, choose an encryption setting and create a password. The default name (or "SSID") of your wireless network will be "NETGEAR." Enter a new, memorable name for your wireless network to help detract would-be hackers from trying to access your router, as most novice computer users with unsecure networks do not know how to change the default network name or institute any other security features. Newer Netgear routers offer WPA or WPA-PSK encryption to secure your network, both of which provide high levels of security. Select either of these. encryption types and create a unique password. This will require all users to enter the password before they can log in to your wireless network. It is important that you create a complex password that has several characters, including numbers. Once you have created a password, click "Confirm Password" to save it. To exit the security settings menu and log off of the router, click "Save" or "Apply" to save the changes you made, then click "Logout" to exit the router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Read more: How to Set up a Secured Wireless Network on Netgear
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
