RTO Mobil Line Mobility Scooter Chair Battery Charger31004 Logo
Posted on Jun 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fuse bl;ows when turned on - RTO Mobil Line Mobility Scooter Chair Battery Charger31004
Anonymous
Level 2:
  • Expert 177 Answers
  • Posted on Jun 05, 2010
Anonymous
Expert
Level 2:
Answers
177
Questions
Helped
115023
Points
342
Hi. Is it the line fuse or the output fuse that blows? Does it blow if it is not connected to the machine.
It is probably best in the long run if you purchase a new charger for your machine. Some older chargers are simple regulation circuits, and most of the newer ones operate on a high frequency switching power supply mode, and have complex circuitry.
If you can get your old charger fixed by an electronics serviceman, it would be a good idea to test it by recording a battery charge with a data logger, to make sure it is charging at the correct voltage levels.
Buying a new charger might mean that you will save destroying a set of batteries as well.
We have here testers for batteries and chargers where the data logger does a voltage test every 10 seconds. We can record a charger for 4 days, and download it to a PC. We have found a few chargers that overcharge. This will eventually destroy the batteries.
Good luck. Neil.
My 2010 grand vitra headlights and tail lights are turned on but don't work ? Ow do I fix ith
Look in your glove box for the owners manual, Check the manual for the location of the fuse box and check the head light tail light fuses.
1helpful
Heater fan has stopped blowing. Just before this happened a lound droning/whining noiuse came from front of vehicle.
From you're description I'd say the blower moter has
cooked a bearing. Check fuse #1 and #2 both are 15amp. They're in the fuse block behind the coin tray
on the lower left side of the dash. They usually go first if the bl moter locks up. To do a quick test unplug the bl moter, located behind the right side of
the dash. Turn the fan switch off and replace the fuses. Plug the blower in and turn it on, if it pop's the
fuses again replace the blower moter. Hope this helps.
3helpful
How do you fix water damage in a nokia bl 4c phone
Do NOT turn it on. remove battery, bury in Tupperware bowl of rice and seal . leave 3 weeks as rice will absorb all the moisture in the phone.
If you HAVE tried to turn it on, you are most likely SOL now.
2answers
I have a 1986 prelude that won't start.
DOES THE CAR SOUND LIKE IT WANTS TO TURN OVER AT ALL?
Why are you having to jump it? Bad battery...too weak....weak battery not supplying enough juice to the starter to turn the motor over....
1helpful
Dodge Caravan 1990 front Windshield Wipers Don't Turn on.
If the Fuses are good and the Rear Works the Cause will be the Wiper Motor for the Windshield Wipers. Please Rate My Response! Thanks!
2answers
Heater control panel
oh my god mine does the same. but sometimes mine will stay all the way over on the red side and still bl.ow cold air. im freaking out thinking i need new heater. it was 29 degrees here today.....
Comp shuts off
Coils could be dirty. Compressor could be getting too hot and cutting off. Will have one fan motor that turns condenser fan and evaporator blower.
Top RTO Health & Beauty Experts
Rob Hill
Rob Hill
Thomas Perkins
Thomas Perkins
Harsal Patel
Harsal Patel
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
