Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Logo
Posted on Jun 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clean button is flashing
Started the dishwasher. Was going. time remaining read 75 min. Went down to 63 min. then made this horrible noise and stuck at 63 min. Cancelled and re-started. Was going ok until 62 minutes remaining the went down to 2 min. remaining and clean light flashing. Hit cancel and went into the start mode with the lines in the time remaining spot. Hit cancel went back to 2 minutes and clean light flashing. That was 2 days ago and the clean light is still flashing.
Anonymous
Level 3:
  • Master 8,619 Answers
  • Posted on Jun 02, 2010
Anonymous
Master
Level 3:
Answers
8619
Questions
Helped
2150211
Points
26471
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Steve Winawer
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 30, 2014
Steve Winawer
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
908
Points
I just tried the high temp, heated dry, high temp, heated dry. All the control panel lights lit but if I press clear after that it's the same flashing clean light.
The start button flashing continuously and the filter area seems to be full of water but when I take it out it is perfectly clean. I have switched the machine on and off several times but each time the...
Please clarify what you mean by "..but when I take it out it is perfectly clean.." are you saying the water in the filter area is clean.
Turn the power off and take out all the water by hand using a small container. Turn the power back on.
If there is no change in the fault, it is likely the flood switch at the base of the dishwasher is triggering and shutting the machine down.
Dishwasher cycle runs until 63 minutes remaining then times out
perhaps the water is not getting hot enough and the machine is waiting for this. test the heater.
2helpful
Started to get a clicking noise from the electic panel of my Frigidare PLDB998 dishwasher for a few loads and then it went dead. Its only a few years old
Did you ever find a solution? I have what sounds like the same problem. The time keeps ticking down but it flashes between CL and the time while the clicking sound is going, and it sometimes make a clunking sound while this is happening as well.
Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
2helpful
2answers
Lock on light flashing
I finally decided to calm down and use my head and managed to solve the problem. I read the instructions that are on the top of the dishwasher door. ( Smart move on my part HUH!) It said that when the door lock light is on everything is disabled. Hold the air/dry button down for 4 seconds and the lock light will go out. Guess what, IT WORKED. Here is what I learned from this. Always read all instructions. I spent $9.95 for an answer that was right in front of me. Humans can be so dumb I am!!!!
Sensing light comes on and then the timer stop going down
I do nto have a solution- just the exact same problem. My machine gets stuck on 76 when doing a "normal wash" . last night I hit cancel and drain, then went to "time saver" and ran the wash and it seemed to work fine. Funny that both of our amchines stop at 76. Any ideas?
Dishwasher making loud humming noise
The most common cause of the hum/grinding sound, and often poor cleaning - is a blocked filter or debris stuck below that filter.
Pretty easy fix: Get a phillips screwdriver near by. Pull out the lower rack (the upper rack can come out if you pull the little gray thingeys on the front of the upper rails.)
Remove the lower spray arm -- just pull it straight up. Remove nine silver screws from the sump area that holds the filter down. Pull the filter up and out. Rinse the filter as best you can.
While the filter removed, with a flash light inspect all over the sump area - looking for stuff that should not be there and clean it out. Watch out for broken glass!
Replace the filter, screws and the spray arm. Fire it up and check your results!
Good Luck!
2answers
Kitchenaid dishwasher will not start
sounds like theres something stuck in the drain pump.hope this helps.
23helpful
5answers
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 • Dishwashers
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
