I do not know the password to access my phone. I have gone through all the steps to reset the pw using feature 983 - admin - change - change pw. It is suppose to default back to 0000 but this does not occur. I am using a Nortel Networks 16 line phone. Thanks
I've never seen Change>change pw. when administering from a telephone set. Are you using nortel element manager to access programming via the network?I've never seen Change>change pw. when administering from a telephone set. Are you using nortel element manager to access programming via the network?
You can't post conmments that contain an email address.
Try using FEATURE **2223772 2223772#. This is the access server admin. There might be a path there to reset passwords. On the MICS side use FEATURE **266344 266344# to access the system programming and password reset features. The best place to get free help from telco professionals (especially Nortel) visit Telephone Tech Talk - http://sundance-communications.com/forum/
feature 985 shows you your vm extension #.
feature 983 then try 1029999 (if password was changed to 9999 or something else)
or maybe feature 983 then 738662 'ok' then 266344 'ok'. depending on the norstar system you have.
these are some codes to enter the vm management. What are you trying to do, reset a vm password or other system programming?
If it's for someone else's extension, you go into Admin (Feature 983) and hit Mailbox, Chng, type in the mailbox number and hit reset. This will reset it to 0000. If you've forgotten the admin password, I found a great online cheat sheet on how to change it, let me know if you need it.
To reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000. 1020000 if you have 3 digit intercom numbers. Once that's done you can go into admin programming to default your password back to 0000.
It sounds like you've either deleted your own mailbox or reset the password to 0000 and changed the password to the administrator mailbox. To reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000. 1020000 if you have 3 digit intercom numbers. Once that's done you can go into admin programming to default your password back to 0000.
The best thing to do at this point is to reset the admin. password. To reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000.
To reset your voice mail password, press feature 983 the screen should say log: enter 120000 (default password) the display should say mbox, AA, and othr above the three soft keys press the mbox soft key the screen should say add, del, and chng above the soft keys press the chng soft key enter in the mailbox number you wish to reset the password on press ok the screen should say reset and next above the soft keys press the reset soft key press the Rls key your password should be reset to 0000
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000.
Press Feature * 0 and then press you intercom button - This will identify the extension # of the phone you are using/ This will also identify any button on the phone
assumming your extension is 3 digits;
enter Feature 983 and at the log prompt enter 1020000 then press ok. This is 102 for the mb and 0000 for the password. If you get successfully logged in you can choose mbox then change and then enter your mb # . The first thing you will see is PASSWORD with RESET under password. Press the softkey under reset to rest the password to 0000. Now try to log back into your mb using 0000 as the password.
If you can't get into the admin mb with 1020000 then do this to reset the password for the admin mb..
Nortel Callpilot PSWD reset
Admin password reset
F985
enter 9
the password is- 73738767793
