Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
Posted on Aug 19, 2017
I have a bissell pro heat model 7901-B that has power but no water circulation. I was told that the previous owner used it without water and that she couldn't get it the power on. I bought it off of her and cleaned it out and now the power works, but there is no water circulation. The brushes run and heater works, just can't seem to get it to circulate water. Thankyou for your time, Don
4 Related Answers
Anonymous
  • 43501 Answers
  • Posted on Sep 30, 2010
SOURCE: Just bought a new brush, ame part number for
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sfgf
Anonymous
  • 43501 Answers
SOURCE: brushes wont rotate
heatman101
uyk
Anonymous
  • 43501 Answers
SOURCE: Info on how to operate a Bissell Turbo Brush Model 7901-P.
heatman101
345erw
Anonymous
  • 43501 Answers
SOURCE: We have a Bissell Proheat Steam Cleaning machine,
heatman101
hhj
How to replace diverter valve model 7901 bissell pro heat steam
heatman101
g,hk
2helpful
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
PROHEAT BISSEL MODEL 7901-1
inside the upper part of unit there is a metal heating element which the water passes through, its probaly clogged,,,it gets filled with calcium build up from water..in future use distilled water or boil water before putting into these units
2answers
How much soap and how much water do I put in the Bissell pro heat?
You are supposed to buy the Bissell soap. On the bottle depending which cleaner you need. The directions are on the bottle. Please do not use house hold cleaners because you can cause serious damage to the vacuum.
Go here, this pg. shows the 7901-1 click the user guide pdf & print the instruction if you choose:
http://www.bissell.com/Bottom_Menu/Product_Search.aspx?Criteria=7901-1+ProHeat+
Good cleaning!
Please vote..........
6helpful
3answers
Water will not come out to do floor work
HI, I have a very similar Bissell. My problem was that after unscrewing the top plate and looking at the pipes the pipes feeding the front sprays were full of gunge blocking the sprayheads. I managed to flush it through by carefully removing the T connector that feeds the front 2 pipes, placing it back so it stuck out of one of the holes and replacing the water tank and turning on while holding it over a bucket. Black and white bits came out but it did flush through. I am thinking of doing a youtube video - let me know if this will help you!
Chessvalley.
1helpful
Bissel pro heat model 8910
Go to http://bissell.com/images/UserGuides/7901.pdf
This is in pdf format so you need adobe reader to get it, which is free on the net.
Top Bissell Vacuums Experts
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
