Samsung Syncmaster 2033SW Monitor Logo
Posted on Jun 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant detect 1600 x 900 on control panel - display - settings. screen keeps going black and message says not optimum mode, recommend mode 1600x900. bought new monitor yesterday. samsung sync master 2033
Anonymous
Level 2:
Scholar:
  • Expert 103 Answers
  • Posted on Jun 04, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
103
Questions
0
Helped
21000
Points
263
You need to install the driver for your samsung sync master 2033, so the the graphics will improve or updated.
  • Anonymous Jul 10, 2012
    I installed the driver and have all the outputs set (1490x900 at 60mhz). Still.. it's not being picked up by the monitor?!! (PC option is grayed out)
    Please help, I've looked everywhere! The VGA cable is new!
My Samsung monitor displays the message "Not optimum mode; recommended mode 1920x1080 60 hertz - Analog" - whenever I try to boot in a Safe Mode (WinXP). It works fine in a normal mode as well as in VGA...
  1. Navigate to the Control Panel in Microsoft Windows by left-clicking on Start, followed by Settings and then choosing Control Panel.
  2. In the Control Panel window, open Display.
    Note: Depending on how your operating system is setup, you may not see the Display icon. To correct this, click on the link on the left-hand side of the Control Panel window that says Switch to Classic View.
  3. In the Display Properties window, click on the Settings tab.
  4. Toward the bottom of this window, click on the Advanced button.
  5. In the resulting window, which may or may not be tittled Plug and Play Monitor..., click on the Monitor tab.
  6. Locate the Screen refresh rate drop down box in the middle of the window. Under most circumstances, the best choice is the highest rate available. Depending on your issue though, the rate may need to be lowered.
    Note: It is always recommended to keep the Hide modes that this monitor cannot display checkbox checked. Choosing refresh rates outside this range could damage hardware.
  7. Click the OK or Apply button to confirm the changes. If prompted, follow any additional on screen directions.
9helpful
2answers
Not optimum mode recommended mode 1600x900 60 Hz
hi swapnil sharma my problum not optimum mode recommended 1600*900 mode60hz
1helpful
2answers
"Not Optimum Mode","Recommanded Mode 1280
FIXED : Before you start your legacy game, software where the "Recommanded Mode 1280 x 1024 60Hz" keeps showing, change your display FROM VIDEO CARD DISPLAY control application to 1024x768 or your choice.
My Syncmaster 2233 had same problem of "Not optimum mode" box coming on whenever I started any old game like Age of Empires etc. It got fixed by selecting FROM DISPLAY CARD DRIVER CONTROL UTILITY's (mine from Catalyst Control Center) >Set desktop area to > 1024 x 768 in my case BEFORE STARTING old application/game. Switch back to your normal resolution after you are done with this application.
Hope this helps.
Regards
Saurabh
Hooked up hp 2009m monitor to hp 735w and a message keeps coming up "input signal out of range change settings to 1600X900 - 60Hz. how do u change this
Hello
I hate that.
Try this reboot pc and tap f8 key while rebooting,choose start in safemode as your option.
Once pc starts go to control panel,display advanced options and select default.Or 800x600
Reboot again,screen will probably not be what you want ,so re adjust again in control panel.
3helpful
Resolution problem
reset your computer and press F8 F8 immedeatly and keep pressing untill menu appears .then highlight on enable vga mode and press enter your problem will be solved thenk you
3answers
Hi I've got a Samsung TFT monitor -Syncmaster 710V - that gives an error message.Message reads: Not optimum mode Recommended Mode: 1280 x 1024 60Hz This screen is impossible to get rid of. Anyone know the...
Try to change the desktop display settings, see screenshots below, see if it works
Right click on your destop and go to properties > settings
  1. Set your Screen resolution to 1280X1024
  2. Then click advanced and go to Monitor and set the refresh rate to 60 Hertz.
A box stating not optimum mode-get distorted internet images
Sounds like your resolution is not set correctly.
Try going to Start-->Control Panel-->Display and choose the Settings Tab
Under there change the resolution slider bar to 1280x1024
Should do the trick!
I have a 913t monitor and about 3 months ago it started to go to a black screen with an error message "not optimum mode recommend 1280 x 1024 60 hz" any help???
Click START-SETTINGS- CONTROLL PANEL - DISPLAY - select the SETTINGS tab at the top - click onthe ADVANCED button (bottom right)- select the monitor tab- in the screen refresh rate dropdown box select 60htz- click on apply & ok - back at the display properties page , slide the slider for screen resolution to 1280x1024- click apply and ok. restart the computer. this show resize your desktop to the correct resolution and refresh rate recommended by your information.
2answers
I have an error message on my screen which ios moving around. It says - 'not optimum mode. Recommended mode : 1280 x1024 60Hz'.
Sounds like you have an LCD monitor. LCD monitors look best in their native resolution. Yours must be 1280x1024. You need to (assuming this is a Windows PC) right click on the desktop and choose Personalize, Display Settings (Vista) or Properties, Settings (XP or older). Set the slider to 1280x1024. It'll confirm the change and then the message should never reappear.
1helpful
Not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
