you did not specify the company name of your writer.
you can change the speed of your writer using a tool called Media Code Speed Edit (MCSE) which is able tomake your DVD writer read and writer faster. If youhave LiteOn, Benq, PHILIPS, HP, LG, NEC, newer PIONEER, Cyberhome,Gigabyte, Samsung and Artec DVD writers, you have a good chance to playwith MCSE and speed up your drive.
MediaCodeSpeedEdit allows you to change the write speed for your mediaand to add new media codes to your firmware by renaming an alreadyavailable media code. The new media code name can be entered manuallyor can be imported from the DVD Identifier media code output to be surethat no special characters are lost. This kind of media code renamingwill remove the original media code name from the patched firmware, soit is no longer supported by the firmware.
Real adding of additional media code names would mean to shift andextend all internal media code tables or patching all media codescanner for all supported firmwares, which would be a quite complextask. So don't do it if you don't know what you are doing.
MCSE basically hack or edit the firmware for your DVD writer and thenyou flash the hacked firmware to update your DVD writer to supportfaster read or write speed. If you don't know where to get your DVDwriter's firmware, you can head to Media CodeSpeed Edit forum to get help. Here is the link to download MCSE
http://www.anonym.to/?http://ala42.cdfreaks.com/MCSE/MediaCodeSpeedEdit.zipplease rate the solution if you like..
