SOURCE: Blinking amber light on modem icon
that means there is usually a problem with your modem. you know how to hook up a router, right? usually you unplug power from both devices, plug in your modem and let it load, then plug in your router. (with some isp's id will work the other way around.
SOURCE: Belkin Wireless Modem Router, model F5D7634-4.
If the reset did not help ,i would suggest you talk to the Belkin Support team and get a replacement. Since its a new router, I assume it has an up to date firmware .
SOURCE: belkin N router modem light flashing amber
download this firmware file and update in the router. http://cache-www.belkin.com/support/dl/f5d8633-4_ww_1.01.06r1.bin
SOURCE: BELKIN N+ WIRELESS ROUTER SECURITY
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
