Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
How to reset the ink level of my hp officejet 6500
    Scholar:
  • 75 Answers
Checking ink levelsUse one of the following methods to check the ink levels. Method one: Check the ink levels from the HP All-in-One The ink level is displayed on the main screen of the control panel display. Locate the two icons that represent the print cartridges. The icon on the left is for the color cartridge and the icon on the right is for the black cartridge.
  • The exclamation mark (! ) symbol indicates a low ink level.
  • The question mark (? ) symbol indicates the product cannot determine the status of the print cartridge. This might be because the cartridge is refilled.
Figure 1: Ink levels on the control panel displayhow to reset the ink level of my hp officejet 6500 - c01362755.gif 1 - Exclamation mark indicates low ink in the color cartridge 2 - Ink level in the black cartridge is OK Method two: Check the ink levels from the computer using the HP ToolboxFollow these steps to check the estimated ink levels using HP Toolbox.
  1. Make sure the product is on and connected to the computer.
  2. Open HP Solution Center .
    • Windows XP: On the Windows taskbar, click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista: On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center .
    • Windows 2000: On the Windows taskbar, click Start , click Programs , point to HP , and then click HP Solution Center .
  3. Click Settings .
  4. Point to Print Settings , and then click Printer Toolbox . Printer Toolbox opens.
  5. Check the ink levels displayed on the Estimated Ink Levels tab.
Posted on Jun 02, 2010
  • SuperTech-IT May 09, 2014
    he said RESET, not CHECK.
    He asked how to RESET the levels, not VIEW them.
SOURCE:
  • 17 Answers
SOURCE: I refilled HP 88 cartridge but printer (Officejet
Under the cartridge is a black like pump - on a new cartridge this is hard and rests firmly on an area inside your printer. As you print, the pump becomes softer - this is how the printer determines it is empty. Once refilled, the pump does not get back to the original state. Open the bottom of the cartridge and put a firm solid piece of folded paper in there - make sure it is steady and re-close cartridge. It will now read as full but may also show full - judge ink levels by the quality of print. Also make sure chip has not expired.
Posted on Feb 17, 2010
SOURCE: HP 5610 officejet all in one: how do i check my ink levels?
Windows users: Turn on printer.....
In the HP Solution Center, click Settings, point to
Print Settings, and then click Printer Toolbox. Click the Estimated
Ink Levels tab.
Mac users:
In the HP Image Zone, click the Devices tab. In the Select Devices area, click the icon for your HP All-in-one. In the Device Options
area, click Settings, and then choose Maintain Printer. If prompted, select your HP All-in-one, and then click Utilities.
Hope this works for you....Eye
Posted on Feb 28, 2009
SOURCE: Deskjet f4185 reset ink level...
for colored is only 3ml and the black is 8ml
Posted on Apr 28, 2010
azeroth009
  • 65 Answers
SOURCE: HOW TO RESET 920 INK
FYI, you cannot reset the ink it self. If your using an HP refilled ink cartridge the warranty of your printer will be void. you need to contact HP right away to purchase new ink cartridges.
If the cartridge has been refilled or remanufactured, 'Low on Ink' or 'Ink Alert' messages may be inaccurate or display incorrectly.
Posted on Jan 31, 2011
ctau
  • 372 Answers
SOURCE: how to check ink level on hp officejet 6210 all-in-one printer
  • Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  • The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • Posted on Mar 22, 2009
    Hp 6500 reset ink level
    take cartridge out and put back in should reset it. some times the printer will be on a time set, so you have to fool it
    May 07, 2012 | HEWLETT-PACKARD OfficeJet 6500 All-In-One...
    How do i reset ink levels on a new hp 6500a printer, is there any1 who actualy knows ????
    what do you mean by resetting the ink levels? to know how to get the estimated ink levels of your printer?
    May 30, 2011 | HP Officejet 6500 Wireless All-in-One...
    My HP Officejet 6500 Wireless printer won't print in black when trying to print from Microsoft Office Word and Microsoft Office Excel or PDF. The ink cartridge is new. I have turned the printer off and...
    I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
    May 17, 2011 | HP Officejet 6500 Wireless All-in-One...
    How to check ink levels for HP6500A Plus Printer
    Normally there are 2 different ways to check ink level on any HP printer
    First one is :
    IF your printer is HP Officejet 6500 Wireless AIO,
    Press Setup button ( ranch like symbol ) on printer front panel
    Use Arrow key ( left or right arrow ) till you find Tools option - Press OK
    User Arrow key to find Ink Level or Ink Gauge - Press OK.
    It should display the ink level.
    If it does not display ink level through this method, it could be for many reasons like printer is not aligned or one of the cartridge is not recognized etc.
    2nd method is from PC
    Click on Settings
    Click on Printer tool box
    Click on Ink level
    Regards,
    Ron
    * Please rate this solution with Thumbs up and Testimony to help us improve providing support
    Apr 20, 2011 | HP Officejet 6500 Wireless All-in-One...
    HOW TO RESET 920 INK CARTRIDGE ON HP OFFICEJET 6500 AFTER HAVING IT REFILL
    Jan 31, 2011 | HP Officejet 6500 Wireless All-in-One...
    Reseting ink 920 cartriges
    Download the manual for HP 6500,
    HP OfficeJet 6500 Wireless Manual.
    It is clearly mentioned in it.
    -Rate if it helped you.
    Apr 10, 2010 | HP Officejet 6500 Wireless All-in-One...
    Recently bought an HP Officejet 6500. How do I
    This video shows how to change ink cartridge on HP 6500 and 6500A
    Oct 31, 2009 | HP Officejet 6500 Wireless All-in-One...
    I have put in the refill Cartridges in HP 6500 but the levels still shows as empty how to I reset the level indicator
    slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
    Oct 10, 2009 | HP Officejet 6500 Wireless All-in-One...
    Instructions on how to refill an hp920xl printer cartridge
    http://h10032.www1.hp.com/ctg/Manual/c01669504.pdf
    Download the above manual.....go to page no. 144.
    It has brief direction to reset ink level.
    Sep 17, 2009 | HP Officejet 6500 Wireless All-in-One...
    HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
    12,010 people viewed this question
    Clive
    Clive
    Ekse
    Thomas F. Schneider
