SOURCE: Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer
catriver, Thanks for the advice....the model number is 110.64972300, serial number is MP5012063. Please provide the door hinge P/N and my husband will order and pick up the part. Cutiepie
SOURCE: HE front loader washer door opened during cycle and will not shut
the latch broke within( the hook inwhich actually hold doorshut) , youll need a new latch assy.
SOURCE: Carrier 58 Series Furnace Blower Motor Won't Shut Off
Yes. If the high limit is tripped, the furnace will bring on the fan continuously until the limit resets. Often, they will not reset if tripped repeatedly. If the furnace is too large for your application, you probably are not able to move enough air to keep the heat exchanger cool enough.
SOURCE: HEIL FURNACE W/ WHITE-ROGERS GAS VALVE 36C84/410
The problem might be with your safety switches other than you gas valve poilte
SOURCE: furnace wont start. heil gas furnace. on initial
Yes, inspect the air intake, exhaust pipe, filter and condensate piping for blockage or moisture. Also check for a hole in the hose that goes from the small exhaust blower to the pressure switch or a bad connection on the switch or control board. You may be able to temporalily jump the switch for diagnostic purposes only.
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
