Viking VUWC141 Wine Cooler Logo
Anonymous Posted on Jun 01, 2010
Viking Wine Cellar Temperature Near-Freezing
I've noticed my Viking Wine Cellar randomly dropping its temperature to below 40 degrees despite being set for 55 degrees. The temperature read-out still displays 55 while the actual temperature is much, much lower. When I unplug and replug the unit, the temperature gauge finally starts displaying the accurate temperature.
Question is: What are possible causes for the wine fridge to be over 20 degrees colder than setting?
  • Anonymous Jun 01, 2010
    Thanks. The unit has been with the repair shop for two weeks and they've been unable to replicate the problem. They claim the unit is fine. Is there anyway to diagnose this problem without actually seeing it take place?
  • Anonymous Jun 04, 2010
    I talked to the Viking repair shop. They said when this happened the first time, they replaced the:
    Main Control Board
    Evaporator famister (sp?)
    Product famister (sp?)
    Does that sound like they did everything they could? The issue still persists.
    Thanks!
Anonymous
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Jun 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
13
Questions
Helped
4949
Points
40
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
  • Anonymous Jun 03, 2010
    With intermittent problems like this it is difficult.In the past,we change the the cold control system and we never hear from the customer again.It always seem to solve the problem.You could take the unit back as is and it might be fine for a few weeks or so and then it will happen again.if it was my wine cooler,I would just replace the cold control system and be done with it.
Cuisinart Compressor Wine Cellar high pitched whistling and not cooling
Keep your wine tasting its best! The Cuisinart Private Reserve® Compressor Wine Cellar features a precision refrigeration system that maintains a perfectly balanced temperature. The full flavor of both reds and whites is preserved, no matter how much the room temperature may fluctuate. Touchscreen controls right on the door make it easy to adjust the temperature from 43°F to 64°F, while leading-edge compressor technology ensures consistent cooling. Store up to 18 bottles of wine and champagne in a sleek, modern showcase crafted with slide-out wood-trimmed shelves. The slimline design conserves space, while the contemporary styling and stainless-steel trim stand out to add an on-trend touch to any home.
It is $650 new, so probably worth getting someone to look at it. I would claim on the warranty anyway. It sounds like an inherent fault with them and the text highlighted about is patently not true..
https://www.cuisinart.com/shopping/appliances/wine/cwc-1800cu/
Which brand provides the best wine coolers?
I don't know but if I needed to find out I would look first at the brands used by commercial establishments that buy for long life and reliability.
While it is fashionable for wine to be overcooled, my father's words often come back to me, "if a drink has to be chilled to taste good, it is poor quality".
White wines and pale beers are traditionally kept in a cellar.
Cellar temperatures are between 45 and 54 F; comparatively mild temperatures that for most of the year in the temperate regions no refrigeration is needed...
Oct 14, 2020 • Furniture
Breeze air wkl 3000 blinking temperature al
NEW UNITS HAVE A VISUAL ALARM PRE SET TO KICK ON AT 62 DEGREES OR ABOVE, WHE THE WINE COOLING UNIT READS 62 OR ABOVE IT WILL FLASH "AL" AND THE TEMPERATURE NUMBER THAT FORVED IT TO KICK ON, IT IS JUST A VISUAL ALARM IT WILL NOT TURN UNIT OFF OR STOP IT .
THIS FEATURE WILL SHUT OFF ONCE THE UNIT READS ANY TEMPERATURE BELOW 62 DEGREES.
My thermostat is reading 48 and I can't get it cool enough in my wine cellar to turn off the unit so that I can adjust the temperature up to 55. Is there a place that I can put some ice on to lower the...
IF THE CELLAR TEMPERATURE IS AS YOU SAY 48 DEGREES AND IF YOU ARE TURNING THE SCREW ADJUSTMENT ALL THE WAY TO THE WARMER SETTING COUNTER CLOCK WISE AND THE UNIT DOESNT SHUT OFF YOU HAVE A BAD THERMOSTAT AND NEED TO REPLACE IT
2answers
What is the red light that looks like a snowflake
The snowflake appears when the outside temperature drops to 40 degrees or below, it then changes to red when it is 32 degrees and below. It seems the manufacturer thinks this will assist you with your driving habits on frozen roadways.
I have an Oster 12-bottle wine celler model OWO912H6H that was a Christmas gift in 2007. I just noticed the temperature is 98 degrees and I cannot get it to come down with the down button. I am very...
Hi, could be faulty thermostat, can you check compressor, is compressor running (working), listen to compressor for clicking sound, unplug it(switched off) for about 20 minutes, replug and let it run (work) for another 20 mins. see if temp. drops, what about temp. inside bottle (wine) cooler, is it 98 or colder, more info. could be valuable. check thermostat, check to see if compressor operates, if cooler temp. 98. remove you products, to another cooler, call mechanic.
As I can improve the yield of refrigeration of the digging, it is already difficult to maintain the indicated temperature
Here is the breakdown on this machine by temperature - it only works optimally in a room that is 68-70 degrees, which is a little on the cold side:
to actually reach 7 degrees Celsius, the room temp must be 68 degrees Farenheit or below
to reach 9 C, room must be 70 F or below
to reach 11 C, room must be 72 F or below
ETC...
all problems with this wine cellar will be aggravated during the summer months
Cuisinart Private Reserve wine cellar
It is normal. The goofy thing about this wine cellar is that once the ambient temperature is above 70 degrees - which is actually a low room temperature - the fan works constantly. You would have to make sure the wine cellar is in an area that stays below 68 degrees (brrrr) for it to shut off sometimes.
-Tha Mp3 Doctor
Top Viking Refrigerators Experts
Jay Finke
Jay Finke
Jose Ramirez
john h
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
