My Cd-Rom/DVD-rom don't work. It doesn't open any folder. I thought I have problems with drivers: SCSIVAX DVD/CD-ROM SCSI CdrOM DEVICE DVD-ROM SD-R2102 TOSHIBA LAPTOP SATELLITE 5005-S507 THANKS, OSCAR
  • oscarleonel Apr 10, 2008
    I found the virus Trojan PurityScan, This virus block my CD-DVD Rom and it don't remmove completely by Spyware Doctor or AVG Software. CAn you help me again for solve this problem.
    Sincerely, Oscar
    Sergeant:
  • 221 Answers
According to the Toshiba website, the scsi cd-rom/dvd-rom does not require a driver to operate, but the driver for the scsi controller card it plugs into may need to be reinstalled or updated. Visit the following link, and go to the section labeled scsi cdrom/dvdrom. At the bottom of this section there are two links to websites where you may be able to find the drivers for your scsi controller card.
http://sdd.toshiba.com/main.aspx?Path=8100000000220000000100006598000000E7/810000000C58000000010000659C00002C36
Posted on Apr 09, 2008
  • Mark Kessler Apr 10, 2008
    Is your AVG antivirus software up to date with the latest virus definitions? If it is not, go to the AVG website and update your software, then do a virus scan. (Usually you have to pay for updates, normally on an annual basis). It should detect the trojan and remove it.
    Another fix would be to format the hard drive and reinstall the operating system using the onboard cd/dvd rom drive instead of the scsi drive. This, however, can only be done if you have the operating system disks.
    If all else fails, try uninstalling the AVG antivrus and installing another type of antivirus with firewall (i.e. McAfee, Norton, etc.). Part of the new installation involves doing a virus scan and removing any malware. If the trojan was able to be installed on your computer then your antivirus software was not doing the job it was intended.
6ya staff
SOURCE:
My computer see the unit and this not work S561 Magneto Optical Drive not driver for download for sony company.
you might have to physically unplug the leads for this cd/dvd rw then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
Jun 07, 2011 | Sony RMO-S561 Magneto Optical Drive -...
DVD/CD-ROM > Does not
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd is getting enough power test all leads that are attached to the cd/dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps don
Mar 12, 2011 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Acer 5520 cdrom does not open if you open it and insert a cd it does not recognize it.
make sure that the cd-dvd is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
don
Feb 14, 2011 | Acer (99.B0311.002) Internal 50x CD-ROM...
My Optriarc DVD RW AD-7580s scsi cdrom device is not functioning. This built in to my loptop. I want to be functioned it now.
if this drive is not showing in my computer
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 14, 2011 | ASUS M2N-MX Motherboard
I need a driver for a hitachi gh40f cd rom but i cant find it.
It does not appear that Hitachi is providing any support for their CD-ROM drives; you will have to make a choice to download your driver from one of the many available services. Some are free but may require you to download their driver scanner. You might consider these sources:
http://xpdrivers.com/cd-dvd-blueray/_1_6.cfm or
dvdram-gh40f-scsi-cdrom.fyxm.net/">http://hl-dt-st-dvdram-gh40f-scsi-cdrom.fyxm.net/
Trust this helpful.
Dec 26, 2010 | Hitachi America, Ltd. Hitachi DVD-ROM and...
When the computer is started the cdrom light flashes but will not open when the eject button is pressed and it does not show that there is even a cdrom installed in my computer
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
if this does not fix the problem might be a registry problem
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 03, 2010 | LG Electronics: Electronics GSA-4082B...
Tsstcorp cd dvdw ts-l633a scsi cdrom device can't read the driver or it is corrupt. I am getting error code 39
Using Device Manager, look to see it laptop is sensing the presence of the cd-rom. (if it is not on the list, try removing / rebooting / and then reinstalling cd-rom) If it shows on the list, click to open it's properties and then delete the drivers for cd-rom (this will cause the laptop to reload the drivers on the next reboot) if it still doesn't work, go to micosoft updates and try to update the drivers there. If it still malfunctions, then the cd-rom may be faulty. Try replacing it with another cd-rom and see what you get.
Oct 10, 2009 | Acer Aspire 5500 5570-2609 Laptop
Problem with DVD/CD-Rom drive
Right click on the device name and select properties and you'll open a window with access to enable the device or open the troubleshooter.
Sometimes if you disable, reboot and enable plug & play will reinstall the device.
If your drivers have been corrupted you may be able to roll them back and then update once the drives are working.
You might want to take a trip to windows update and see if it will detect the error and offer you a fix.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 08, 2009 | Computers & Internet
I can't play CD/DVD from my laptop. When i opened the device manager, there are 2 drives: HL-DT-ST DVDRAM GSA-T10N ATA Device and WC6037K IYL929R SCSI CdRom Device. The first device doesn't work when i...
In Laptop obviously there is only one CD/DVD rom drive present.
So first confirm have you got any mark in the device manager entry for WC6037K IYL929R SCSI CdRom Device. If yes then you need to go in the BIOS and detect the Boot priority and enable the CD Rom there.
Check out the event viewer entry if showing any red cross entry related to CD/DVD rom and try to search it out on net.
If the CD/DVD drive is opening or ejecting out then it working and if it is not may be the failure in Drive and need to replace.
Other entry you had mentioned is for RAM (memory)
Nov 04, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
890 people viewed this question
Ekse
Marvin
Marvin
